[SOLVED] AGX Xavier Dev Kit stuck in bootloop after flashing Jetpack 4.6 [Serial logs attached]
Update 2021-12-06: Re-flashing solved the issue
Although this Xavier has been confirmed to work with Jetpack 4.4, I would like to get 4.6 working since we are developing a Triton application.
Jetson model: AGX Xavier Developer Kit
Jetpack version: 4.6
Flashing method: SDK Manager on bare-metal Ubuntu Bionic Beaver (18.04.6) host
After flashing the screen outputs only a white background and green NVIDIA logo for about 10 seconds, then the Xavier reboots itself.
Serial boot logs were obtained as suggested by the docs, I attach them here:
[0010.832] I> Encryption fuse is not ON
[0010.860] I> Loading kernel-dtb ...
[0010.860] I> No kernel-dtb binary path
[0010.860] I> Continue to load from partition ...
[0010.860] W> No valid slot number is found in scratch register
[0010.861] W> Return default slot: _a
[0010.861] I> A/B: bin_type (38) slot 0
[0010.861] I> Loading kernel-dtb from partition
[0010.863] I> Loading partition kernel-dtb at 0x91000000 from device(0x6)
[0010.912] I> Validate kernel-dtb ...
[0010.913] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.915] I> Encryption fuse is not ON
[0010.916] I> Loading ramdisk from rootfs ...
[0010.916] I> Loading ramdisk binary from rootfs ...
[0010.917] I> rootfs path: /sd/boot/initrd
[0011.520] I> Loading ramdisk sig file from rootfs ...
[0011.520] I> rootfs path: /sd/boot/initrd.sig
[0011.533] I> overload load_size to 7238344 (from 7238352)
[0011.533] I> Validate ramdisk ...
[0011.533] I> T19x: Authenticate ramdisk (bin_type: 54), max size 0x4000000
[0011.600] I> Encryption fuse is not ON
[0011.613] I> Kernel hdr @0xa4ae0000
[0011.613] I> Kernel dtb @0x90000000
[0011.614] I> decompressor handler not found
[0011.614] I> Copying kernel image (34484232 bytes) from 0xa4ae0000 to 0x80080000 ... [0011.624] I> Done
[0011.625] I> Updated bpmp info to DTB
[0011.626] I> Ramdisk: Base: 0x92000000; Size: 0x6e72c8
[0011.626] I> Updated initrd info to DTB
[0011.627] W> WARN: Fail to override "console=none" in commandline
[0011.627] I> Active rootfs suffix:
[0011.629] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0011.637] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0011.644] W> No valid slot number is found in scratch register
[0011.650] W> Return default slot: _a
[0011.653] I> Active slot suffix:
[0011.656] I> add_boot_slot_suffix: slot_suffix =
[0011.661] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06aa000 lut_mem=0x2008@0xa06a5000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0011.690] I> Updated bootarg info to DTB
[0011.694] W> MAC addr invalid!
[0011.697] E> Failed to get WIFI MAC address
[0011.701] W> MAC addr invalid!
[0011.704] E> Failed to get Bluetooth MAC address
[0011.708] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:30:06:a9
[0011.715] W> "plugin-manager" doesn't exist, creating
[0011.719] I> Adding /chosen/plugin-manager/cvm
[0011.723] W> "chip-id" doesn't exist, creating
[0011.728] I> Adding /chosen/plugin-manager/chip-id
[0011.733] W> "configs" doesn't exist, creating
[0011.737] I> Adding /chosen/plugin-manager/configs
[0011.741] W> "ids" doesn't exist, creating
[0011.745] I> Adding /chosen/plugin-manager/ids
[0011.750] W> "odm-data" doesn't exist, creating
[0011.754] I> Adding /chosen/plugin-manager/odm-data
[0011.761] W> "memory" doesn't exist, creating
[0011.763] I> [0] START: 0x80000000, END: 0xac000000
[0011.768] I> [1] START: 0xac004000, END: 0xf0ad0000
[0011.772] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0011.777] I> dram_block larger than 80000000
[0011.781] I> [3] START: 0x100000000, END: 0x880000000
[0011.786] I> added [base:0x80000000, size:0x2c000000] to /memory
[0011.792] I> added [base:0xac200000, size:0x44800000] to /memory
[0011.798] I> added [base:0x100000000, size:0x780000000] to /memory
[0011.804] I> Updated memory info to DTB
[0011.808] E> add_disp_param: failed to get display params for du=1
[0011.814] W> "reset" doesn't exist, creating
[0011.818] I> Adding ecid(00000001647c98800800000008010300) to DT
[0011.824] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0011.828] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0011.833] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0011.838] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0011.842] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0011.847] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0011.852] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0011.857] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0011.862] W> "misc-data" doesn't exist, creating
[0011.866] I> Boot-device: eMMC
[0011.869] I> Add boot-sdmmc to plugin-manager/misc-data
[0011.874] I> Add storage-sdmmc to plugin-manager/misc-data
[0011.879] W> Unknown storage device
[0011.883] I> Add serial number:1424520037871 as DT property
[0011.889] I> Plugin-manager override starting
[0011.892] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0011.899] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0011.907] I> Disable plugin-manager status in FDT
[0011.908] I> Plugin-manager override finished successfully
[0011.914] I> tegrabl_load_kernel_and_dtb: Done
[0011.936] I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5497-d3000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Jul 26 12:19:28 PDT 2021
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44800000
[    0.000000] OF: fdt: - 100000000 ,  780000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[    0.000000] bootconsole [tegra_comb_uart0] enabled
[    0.000000] Found tegra_fbmem: 00800000@a06aa000
[    0.000000] Found lut_mem: 00002008@a06a5000
ÿäÿâShutdown state requested 1
Rebooting system ...
ÿâ
[0000.053] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.062] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0000.067] I> Boot-mode: Coldboot
[0000.070] I> Chip revision : A02P
[0000.073] I> Bootrom patch version : 15 (correctly patched)
[0000.078] I> ATE fuse revision : 0x200
[0000.082] I> Ram repair fuse : 0x0
[0000.085] I> Ram Code : 0x2
[0000.088] I> rst_source : 0xb
[0000.090] I> rst_level : 0x1
[0000.094] I> Boot-device: eMMC
[0000.109] I> sdmmc DDR50 mode
[0000.113] W> No valid slot number is found in scratch register
[0000.118] W> Return default slot: _a
[0000.122] I> Active Boot chain : 0
[0000.125] I> Boot-device: eMMC
[0000.128] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.135] I> Temperature = 36000
[0000.138] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.142] W> Skipping boost for clk: BPMP_APB
[0000.146] W> Skipping boost for clk: AXI_CBB
[0000.150] W> Skipping boost for clk: AON_CPU_NIC
[0000.154] W> Skipping boost for clk: CAN1
[0000.158] W> Skipping boost for clk: CAN2
[0000.162] I> Boot-device: eMMC
[0000.165] I> Boot-device: eMMC
[0000.174] I> Sdmmc: HS400 mode enabled
[0000.179] I> ECC region[0]: Start:0x0, End:0x0
[0000.183] I> ECC region[1]: Start:0x0, End:0x0
[0000.187] I> ECC region[2]: Start:0x0, End:0x0
[0000.191] I> ECC region[3]: Start:0x0, End:0x0
[0000.195] I> ECC region[4]: Start:0x0, End:0x0
[0000.200] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.205] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.210] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.214] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.219] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.224] E> FAILED: Thermal config
[0000.231] E> FAILED: MEMIO rail config
[0000.250] I> Boot-device: eMMC
[0000.259] I> sdmmc bdev is already initialized
[0000.332] I> MB1 done
ÿýÿàmain enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
ÿâ
[0000.340] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-938a8cd8)
[0000.341] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.341] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.342] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.348] W> device prod register failed
[0000.351] I> Boot-device: eMMC
[0000.354] I> Boot_device: SDMMC_BOOT instance: 3
[0000.360] I> sdmmc-3 params source = boot args
[0000.363] I> sdmmc bdev is already initialized
[0000.367] I> sdmmc-3 params source = boot args
[0000.376] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.382] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.383] W> No valid slot number is found in scratch register
[0000.388] W> Return default slot: _a
[0000.392] I> Active Boot chain : 0
[0000.395] I> parsing oem signed section of bpmp-fw header done
[0000.401] I> bpmp-fw binary init read from storage
[0000.406] I> oem authentication of bpmp-fw header done
[0000.412] I> bpmp-fw binary done read from storage
[0000.415] I> bpmp-fw: Authentication init Done
[0000.419] I> parsing oem signed section of cpubl header done
[0000.425] I> cpubl binary init read from storage
[0000.429] I> bpmp-fw: Authentication Finalize Done
[0000.434] I> oem authentication of cpubl header done
[0000.439] I> cpubl binary done read from storage
[0000.443] I> cpubl: Authentication init Done
[0000.447] I> parsing oem signed section of rce header done
[0000.452] I> rce binary init read from storage
[0000.457] I> Relocating BR-BCT
[0000.460] I> cpubl: Authentication Finalize Done
[0000.464] I> oem authentication of rce header done
[0000.469] I> rce binary done read from storage
[0000.473] I> rce: Authentication init Done
[0000.478] I> parsing oem signed section of ape header done
[0000.482] I> ape binary init read from storage
[0000.487] I> rce: Authentication Finalize Done
[0000.491] I> oem authentication of ape header done
[0000.495] I> ape binary done read from storage
[0000.500] I> ape: Authentication init Done
[0000.505] I> parsing oem signed section of tos header done
[0000.509] I> tos binary init read from storage
[0000.513] I> ape: Authentication Finalize Done
[0000.518] I> oem authentication of tos header done
[0000.522] I> tos binary done read from storage
[0000.527] I> tos: Authentication init Done
[0000.531] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.537] I> bpmp-fw-dtb binary init read from storage
[0000.542] I> tos: Authentication Finalize Done
[0000.548] I> oem authentication of bpmp-fw-dtb header done
[0000.554] I> bpmp-fw-dtb binary done read from storage
[0000.556] I> bpmp-fw-dtb: Authentication init Done
[0000.561] I> parsing oem signed section of cpubl-dtb header done
[0000.567] I> cpubl-dtb binary init read from storage
[0000.571] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.610] I> oem authentication of cpubl-dtb header done
[0000.610] I> cpubl-dtb binary done read from storage
[0000.611] I> cpubl-dtb: Authentication init Done
[0000.613] I> parsing oem signed section of eks header done
[0000.613] I> eks binary init read from storage
[0000.614] I> cpubl-dtb: Authentication Finalize Done
[0000.615] I> oem authentication of eks header done
[0000.618] I> eks binary done read from storage
[0000.623] I> eks: Authentication init Done
[0000.626] I> eks: Authentication Finalize Done
[0000.631] I> EKB detected (length: 0x410) @ VA:0x52700400
ÿäNOTICE:  BL31: v1.3(release):b5eeb33f7
NOTICE:  BL31: Built : 12:15:32, Jul 26 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 315: key_mgnt_processing .......
hwkey-agent: 223: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
ÿâ
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
ÿá
[0001.134] I> Welcome to Cbootÿâmrq initialized
fmon_post initialized
ÿá
[0001.135] I> Cboot Version: t194-cfa2bc91
[0001.135] I> CPU-BL Params @ 0xf2820000
[0001.135] I>  0) Base:0x00000000 Size:0x00000000
[0001.139] I>  1) Base:0xf1100000 Size:0x00100000
[0001.143] I>  2) Base:0xf2000000 Size:0x00200000
[0001.148] I>  3) Base:0xf1200000 Size:0x00200000
[0001.152] I>  4) Base:0xf1000000 Size:0x00100000
[0001.157] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.161] I>  6) Base:0xf3800000 Size:0x00400000
[0001.165] I>  7) Base:0xf1c00000 Size:0x00400000
ÿâclk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
ÿá[0001.170] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.249] I>  9) Base:0xf0d00000 Size:0x00100000
[0001.254] I> 10) Base:0xf3000000 Size:0x00800000
[0001.258] I> 11) Base:0x40000000 Size:0x00040000
[0001.263] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.267] I> 13) Base:0x40046000 Size:0x00002000
[0001.272] I> 14) Base:0x40048000 Size:0x00002000
[0001.276] I> 15) Base:0xac000000 Size:0x00004000
[0001.281] I> 16) Base:0x4004a000 Size:0x00002000ÿâemc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ÿá
[0001.335] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.340] I> 18) Base:0x4004c000 Size:0x00002000
[0001.344] I> 19) Base:0xf2200000 Size:0x00600000
[0001.349] I> 20) Base:0x4004e000 Size:0x00002000
[0001.353] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.358] I> 22) Base:0x00000000 Size:0x00000000
[0001.362] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.367] I> 24) Base:0xf6000000 Size:0x02000000
[0001.371] I> 25) Base:0x40050000 Size:0x00002000
[0001.376] I> 26) Base:0x40040000 Size:0x00006000
[0001.380] I> 27) Base:0xf1800000 Size:0x00400000
[0001.385] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.389] I> 29) Base:0xf1400000 Size:0x00400000
[0001.394] I> 30) Base:0x00000000 Size:0x00000000
[0001.398] I> 31) Base:0x00000000 Size:0x00000000
[0001.402] I> 32) Base:0xf8000000 Size:0x08000000
[0001.407] I> 33) Base:0x00000000 Size:0x00000000
[0001.411] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.416] I> 35) Base:0xab000000 Size:0x01000000
[0001.420] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.425] I> 37) Base:0xf2800000 Size:0x00800000
[0001.429] I> 38) Base:0x80000000 Size:0x20000000
[0001.434] I> 39) Base:0xb0000000 Size:0x08000000
[0001.438] I> 40) Base:0x00000000 Size:0x00000000
[0001.443] I> 41) Base:0x00000000 Size:0x00000000
[0001.447] I> 42) Base:0x00000000 Size:0x00000000
[0001.452] I> 43) Base:0x00000000 Size:0x00000000
[0001.456] I> 44) Base:0x00000000 Size:0x00000000
[0001.460] I> 45) Base:0x00000000 Size:0x00000000
[0001.465] GIC-SPI Target CPU: 0
[0001.468] Interrupts Init done
[0001.471] calling constructors
[0001.474] initializing heap
[0001.476] I> Heap: [0xa0699b80 ... 0xab000000]
[0001.481] initializing threads
[0001.483] initializing timers
[0001.486] creating bootstrap completion thread
[0001.491] top of bootstrap2()
[0001.493] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.498] initializing platform
[0001.501] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.506] W> device prod register failed
[0001.510] I> Bl_dtb @0xaaf00000
[0001.517] W> "plugin-manager" doesn't exist, creating
[0001.518] W> "ids" doesn't exist, creating
[0001.522] W> "connection" doesn't exist, creating
[0001.527] W> "configs" doesn't exist, creating
[0001.538] E> failed to read label property for node 227172: 13
[0001.541] E> failed to read reg property for node 227260: 13
[0001.545] E> failed to read label property for node 227312: 13
[0001.549] E> failed to read label property for node 227380: 13
[0001.554] E> failed to read label property for node 227416: 13
[0001.560] E> failed to read label property for node 227452: 13
[0001.566] E> failed to read reg property for node 227520: 13
[0001.571] E> failed to read label property for node 227572: 13
[0001.578] I> Find /i2c@3160000's alias i2c0
[0001.580] I> Reading eeprom i2c=0 address=0x50
[0001.610] I> Device at /i2c@3160000:0x50
[0001.610] I> Reading eeprom i2c=0 address=0x56
[0001.634] I> Device at /i2c@3160000:0x56
[0001.636] I> Find /i2c@3180000's alias i2c2
[0001.636] I> Reading eeprom i2c=2 address=0x54
[0001.638] E> I2C: slave not found in slaves.
[0001.638] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.639] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.640] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.648] E> eeprom: Failed to read I2C slave device
[0001.653] I> Eeprom read failed 0x3526070d
[0001.657] I> Reading eeprom i2c=2 address=0x57
[0001.662] E> I2C: slave not found in slaves.
[0001.666] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.673] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.679] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.688] E> eeprom: Failed to read I2C slave device
[0001.693] I> Eeprom read failed 0x3526070d
[0001.697] I> Reading eeprom i2c=2 address=0x52
[0001.702] E> I2C: slave not found in slaves.
[0001.706] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.713] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.719] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.729] E> eeprom: Failed to read I2C slave device
[0001.733] I> Eeprom read failed 0x3526070d
[0001.738] I> Find /i2c@c240000's alias i2c1
[0001.741] I> Reading eeprom i2c=1 address=0x52
[0001.747] E> I2C: slave not found in slaves.
[0001.750] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.758] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.763] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.773] E> eeprom: Retry to read I2C slave device.
[0001.778] E> I2C: slave not found in slaves.
[0001.782] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.789] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.795] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.804] E> eeprom: Failed to read I2C slave device
[0001.809] I> Eeprom read failed 0x3526070d
[0001.813] I> Reading eeprom i2c=1 address=0x50
[0001.818] E> I2C: slave not found in slaves.
[0001.822] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.829] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.835] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.845] E> eeprom: Retry to read I2C slave device.
[0001.849] E> I2C: slave not found in slaves.
[0001.853] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.861] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.867] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.876] E> eeprom: Failed to read I2C slave device
[0001.881] I> Eeprom read failed 0x3526070d
[0001.885] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0001.890] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.901] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0001.906] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.918] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.926] W> "i2c@3160000" doesn't exist, creating
[0001.929] W> "module@0x50" doesn't exist, creating
[0001.934] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.941] W> "module@0x56" doesn't exist, creating
[0001.947] I> Adding plugin-manager/cvm
[0001.949] W> "chip-id" doesn't exist, creating
[0001.953] I> Adding plugin-manager/chip-id/A02P
[0001.958] I> Plugin-manager override starting
[0001.963] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.972] I> node /plugin-manager/fragement-soft-wdt matches
[0001.980] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.983] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.993] I> Disable plugin-manager status in FDT
[0001.994] I> Plugin-manager override finished successfully
[0001.995] I> gpio framework initialized
[0002.000] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.007] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.014] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.021] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.029] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.035] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.041] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.049] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.057] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.063] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.071] I> fixed regulator driver initialized
[0002.082] I> register 'maxim' power off handle
[0002.083] I> virtual i2c enabled
[0002.083] I> registered 'maxim,max20024' pmic
[0002.085] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.092] I> Boot-device: eMMC
[0002.095] I> Boot_device: SDMMC_BOOT instance: 3
[0002.103] I> sdmmc-3 params source = boot args
[0002.104] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0002.109] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.120] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.125] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.136] I> sdmmc bdev is already initialized
[0002.140] I> sdmmc-3 params source = boot args
[0002.175] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.187] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.198] I> enabling 'vdd-hdmi-5v0' regulator
[0002.204] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.204] I> hdmi cable connected
[0002.206] W> set volts not configured for 'vdd-1v0'
[0002.209] W> set volts not configured for 'vdd-1v8-hs'
[0002.209] I> retrieved tmds range from prod_list_hdmi_soc
[0002.214] E> invalid display type
[0002.218] E> invalid display type
[0002.219] E> cannot find any other nvdisp nodes
[0002.235] I> edid read success
[0002.247] I> edid read success
[0002.247] I> width = 640, height = 480, frequency = 25174825
[0002.248] I> width = 1920, height = 1080, frequency = 148500000
[0002.248] I> width = 1360, height = 768, frequency = 84750000
[0002.249] I> width = 1920, height = 1080, frequency = 148500000
[0002.249] I> width = 1920, height = 1080, frequency = 148351648
[0002.253] I> width = 1920, height = 1080, frequency = 148351648
[0002.259] I> width = 1920, height = 1080, frequency = 74175824
[0002.265] I> width = 1920, height = 1080, frequency = 74175824
[0002.271] I> width = 1920, height = 1080, frequency = 74175824
[0002.276] I> width = 1280, height = 720, frequency = 74175824
[0002.282] I> width = 1280, height = 720, frequency = 74175824
[0002.288] I> width = 720, height = 576, frequency = 26973026
[0002.293] I> width = 720, height = 480, frequency = 26973026
[0002.299] I> width = 640, height = 480, frequency = 25174825
[0002.304] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.314] I> hdmi_enable, starting HDMI initialisation
[0002.319] I> hdmi_enable, HDMI initialisation complete
[0002.329] I> Load in CBoot Boot Options partition and parse it
[0002.336] E> Error -9 when finding node with path /boot-configuration
[0002.336] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.340] I> Using default boot order
[0002.343] I> boot-dev-order :-
[0002.346] I> 1.sd
[0002.348] I> 2.usb
[0002.349] I> 3.nvme
[0002.351] I> 4.emmc
[0002.353] I> 5.net
[0002.355] I> Hit any key to stop autoboot:	4	3	2	1
[0004.363] initializing target
[0004.363] calling apps_init()
[0004.364] starting app kernel_boot_app
[0004.383] I> found decompressor handler: lz4-legacy
[0004.384] I> decompressing BMP blob ...
[0004.396] I> Kernel type = Normal
[0004.397] I> ########## SD (0) boot ##########
[0004.397] I> Found sdcard
[0004.400] I> enabling 'vdd-sdmmc1-sw' regulator
[0004.405] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.565] I> sdmmc SDR mode
[0004.579] I> -0 params source =
[0004.589] I> Found 11 partitions in SDCARD (instance 0)
[0004.590] I> Look for boot partition
[0004.590] I> Fallback: assuming 0th partition is boot partition
[0004.596] I> Detect filesystem
[0004.617] I> Loading kernel-bootctrl from partition
[0004.618] I> Loading partition kernel-bootctrl at 0xa4ae0000 from device(0x6)
[0004.642] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.643] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.643] I> Loading extlinux.conf ...
[0004.644] I> Loading extlinux.conf binary from rootfs ...
[0004.644] I> rootfs path: /sd/boot/extlinux/extlinux.conf
[0004.674] I> Loading extlinux.conf sig file from rootfs ...
[0004.674] I> rootfs path: /sd/boot/extlinux/extlinux.conf.sig
[0004.691] I> Validate extlinux.conf ...
[0004.691] I> T19x: Authenticate extlinux.conf (bin_type: 54), max size 0x2000
[0004.691] I> Encryption fuse is not ON
[0004.692] I> L4T boot options
[0004.692] I> [1]: "primary kernel"
[0004.692] I> Enter choice:
[0007.694] I> Continuing with default option: 1
[0007.694] I> Loading kernel ...
[0007.694] I> Loading kernel binary from rootfs ...
[0007.695] I> rootfs path: /sd/boot/Image
[0010.508] I> Loading kernel sig file from rootfs ...
[0010.508] I> rootfs path: /sd/boot/Image.sig
[0010.521] I> overload load_size to 34484232 (from 34484240)
[0010.522] I> Validate kernel ...
[0010.522] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.836] I> Encryption fuse is not ON
[0010.851] I> Loading kernel-dtb ...
[0010.851] I> No kernel-dtb binary path
[0010.852] I> Continue to load from partition ...
[0010.852] W> No valid slot number is found in scratch register
[0010.852] W> Return default slot: _a
[0010.853] I> A/B: bin_type (38) slot 0
[0010.853] I> Loading kernel-dtb from partition
[0010.854] I> Loading partition kernel-dtb at 0x91000000 from device(0x6)
[0010.903] I> Validate kernel-dtb ...
[0010.904] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.906] I> Encryption fuse is not ON
[0010.907] I> Loading ramdisk from rootfs ...
[0010.908] I> Loading ramdisk binary from rootfs ...
[0010.908] I> rootfs path: /sd/boot/initrd
[0011.510] I> Loading ramdisk sig file from rootfs ...
[0011.511] I> rootfs path: /sd/boot/initrd.sig
[0011.523] I> overload load_size to 7238344 (from 7238352)
[0011.524] I> Validate ramdisk ...
[0011.524] I> T19x: Authenticate ramdisk (bin_type: 54), max size 0x4000000
[0011.590] I> Encryption fuse is not ON
[0011.597] I> Kernel hdr @0xa4ae0000
[0011.597] I> Kernel dtb @0x90000000
[0011.598] I> decompressor handler not found
[0011.598] I> Copying kernel image (34484232 bytes) from 0xa4ae0000 to 0x80080000 ... [0011.604] I> Done
[0011.605] I> Updated bpmp info to DTB
[0011.606] I> Ramdisk: Base: 0x92000000; Size: 0x6e72c8
[0011.606] I> Updated initrd info to DTB
[0011.607] W> WARN: Fail to override "console=none" in commandline
[0011.610] I> Active rootfs suffix:
[0011.613] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0011.621] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0011.628] W> No valid slot number is found in scratch register
[0011.634] W> Return default slot: _a
[0011.637] I> Active slot suffix:
[0011.640] I> add_boot_slot_suffix: slot_suffix =
[0011.645] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06aa000 lut_mem=0x2008@0xa06a5000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0011.674] I> Updated bootarg info to DTB
[0011.678] W> MAC addr invalid!
[0011.681] E> Failed to get WIFI MAC address
[0011.685] W> MAC addr invalid!
[0011.688] E> Failed to get Bluetooth MAC address
[0011.692] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:30:06:a9
[0011.699] W> "plugin-manager" doesn't exist, creating
[0011.704] I> Adding /chosen/plugin-manager/cvm
[0011.708] W> "chip-id" doesn't exist, creating
[0011.712] I> Adding /chosen/plugin-manager/chip-id
[0011.717] W> "configs" doesn't exist, creating
[0011.721] I> Adding /chosen/plugin-manager/configs
[0011.725] W> "ids" doesn't exist, creating
[0011.729] I> Adding /chosen/plugin-manager/ids
[0011.734] W> "odm-data" doesn't exist, creating
[0011.738] I> Adding /chosen/plugin-manager/odm-data
[0011.745] W> "memory" doesn't exist, creating
[0011.747] I> [0] START: 0x80000000, END: 0xac000000
[0011.752] I> [1] START: 0xac004000, END: 0xf0ad0000
[0011.756] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0011.761] I> dram_block larger than 80000000
[0011.765] I> [3] START: 0x100000000, END: 0x880000000
[0011.770] I> added [base:0x80000000, size:0x2c000000] to /memory
[0011.776] I> added [base:0xac200000, size:0x44800000] to /memory
[0011.782] I> added [base:0x100000000, size:0x780000000] to /memory
[0011.789] I> Updated memory info to DTB
[0011.792] E> add_disp_param: failed to get display params for du=1
[0011.798] W> "reset" doesn't exist, creating
[0011.802] I> Adding ecid(00000001647c98800800000008010300) to DT
[0011.808] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0011.812] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0011.817] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0011.822] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0011.826] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0011.831] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0011.836] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0011.841] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0011.846] W> "misc-data" doesn't exist, creating
[0011.850] I> Boot-device: eMMC
[0011.853] I> Add boot-sdmmc to plugin-manager/misc-data
[0011.858] I> Add storage-sdmmc to plugin-manager/misc-data
[0011.863] W> Unknown storage device
[0011.867] I> Add serial number:1424520037871 as DT property
[0011.873] I> Plugin-manager override starting
[0011.876] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0011.883] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0011.891] I> Disable plugin-manager status in FDT
[0011.892] I> Plugin-manager override finished successfully
[0011.898] I> tegrabl_load_kernel_and_dtb: Done
[0011.919] I> Kernel EP: 0x80080000, DTB: 0x90000000
ÿâ
[0000.175] I> Sdmmc: HS400 mode enabled
[0000.196] I> ECC region[4]: Start:0x0, End:0x0
ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
[0000.352] I> Boot-device: eMMC
[0000.355] I> Boot_device: SDMMC_BOOT instance: 3
[0000.368] I> sdmmc-3 params source = boot args
[0000.420] I> parsing oem signed section of cpubl header done
[0000.448] I> parsing oem signed section of rce header done
[0000.453] I> rce binary init read from storage
[0000.465] I> oem authentication of rce header done
[0000.483] I> ape binary init read from storage
[0000.496] I> ape binary done read from storage
[0000.514] I> ape: Authentication Finalize Done
[0000.523] I> tos binary done read from storage
[0000.572] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.614] I> eks binary init read from storage
[0000.627] I> eks: Authentication Finalize Done
ÿâ
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
ec_mrq initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
ÿá
ÿá
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
ÿá[0001.161] I>  6) Base:0xf3800000 Size:0x00400000
[0001.241] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.245] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.250] I>  9) Base:0xf0d00000 Size:0x00100000
[0001.259] I> 11) Base:0x40000000 Size:0x00040000
[0001.268] I> 13) Base:0x40046000 Size:0x00002000
ÿá[0001.276] I> 15) Base:0xac000000 Size:0x00004000
ÿâfmon_debugfs initialized
mail_fs initialized
profile initialized
mods initialized
dt_fs initialized
initializing target
calling apps_init()
starting app shell
] ÿá[0001.286] I> 16) Base:0x4004a000 Size:0x00002000
[0001.336] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.341] I> 18) Base:0x4004c000 Size:0x00002000
[0001.345] I> 19) Base:0xf2200000 Size:0x00600000
[0001.350] I> 20) Base:0x4004e000 Size:0x00002000
[0001.354] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.363] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.372] I> 25) Base:0x40050000 Size:0x00002000
[0001.381] I> 27) Base:0xf1800000 Size:0x00400000
[0001.390] I> 29) Base:0xf1400000 Size:0x00400000
[0001.399] I> 31) Base:0x00000000 Size:0x00000000
[0001.403] I> 32) Base:0xf8000000 Size:0x08000000
[0001.408] I> 33) Base:0x00000000 Size:0x00000000
[0001.412] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.421] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.430] I> 38) Base:0x80000000 Size:0x20000000
[0001.439] I> 40) Base:0x00000000 Size:0x00000000
[0001.448] I> 42) Base:0x00000000 Size:0x00000000
[0001.457] I> 44) Base:0x00000000 Size:0x00000000
[0001.461] I> 45) Base:0x00000000 Size:0x00000000
[0001.466] GIC-SPI Target CPU: 0
[0001.469] Interrupts Init done
[0001.477] I> Heap: [0xa0699b80 ... 0xab000000]
[0001.484] initializing timers
[0001.487] creating bootstrap completion thread
[0001.494] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.499] initializing platform
[0001.502] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.507] W> device prod register failed
[0001.511] I> Bl_dtb @0xaaf00000
[0001.519] W> "ids" doesn't exist, creating
[0001.523] W> "connection" doesn't exist, creating
[0001.539] E> failed to read label property for node 227172: 13
[0001.542] E> failed to read reg property for node 227260: 13
[0001.544] E> failed to read label property for node 227312: 13
[0001.550] E> failed to read label property for node 227380: 13
[0001.555] E> failed to read label property for node 227416: 13
[0001.572] E> failed to read label property for node 227572: 13
[0001.581] I> Reading eeprom i2c=0 address=0x50
[0001.611] I> Reading eeprom i2c=0 address=0x56
[0001.635] I> Device at /i2c@3160000:0x56
[0001.649] E> eeprom: Failed to read I2C slave device
[0001.654] I> Eeprom read failed 0x3526070d
[0001.658] I> Reading eeprom i2c=2 address=0x57
[0001.674] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.680] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.689] E> eeprom: Failed to read I2C slave device
[0001.694] I> Eeprom read failed 0x3526070d
[0001.698] I> Reading eeprom i2c=2 address=0x52
[0001.714] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.720] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.734] I> Eeprom read failed 0x3526070d
[0001.739] I> Find /i2c@c240000's alias i2c1
[0001.742] I> Reading eeprom i2c=1 address=0x52
[0001.748] E> I2C: slave not found in slaves.
[0001.764] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.790] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.796] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.805] E> eeprom: Failed to read I2C slave device
[0001.810] I> Eeprom read failed 0x3526070d
[0001.814] I> Reading eeprom i2c=1 address=0x50
[0001.830] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.836] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.850] E> I2C: slave not found in slaves.
[0001.854] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.862] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.877] E> eeprom: Failed to read I2C slave device
[0001.882] I> Eeprom read failed 0x3526070d
[0001.886] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0001.891] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.902] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0001.907] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.930] W> "module@0x50" doesn't exist, creating
[0001.935] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.942] W> "module@0x56" doesn't exist, creating
[0001.948] I> Adding plugin-manager/cvm
[0001.950] W> "chip-id" doesn't exist, creating
[0001.954] I> Adding plugin-manager/chip-id/A02P
[0001.971] I> node /plugin-manager/fragement-soft-wdt matches
[0001.979] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.982] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.994] I> Disable plugin-manager status in FDT
[0002.008] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.022] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.030] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.036] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.042] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.050] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.064] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.084] I> registered 'maxim,max20024' pmic
[0002.086] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.093] I> Boot-device: eMMC
[0002.104] I> sdmmc-3 params source = boot args
[0002.126] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.137] I> sdmmc bdev is already initialized
[0002.141] I> sdmmc-3 params source = boot args
[0002.171] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.184] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.195] I> enabling 'vdd-hdmi-5v0' regulator
[0002.201] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.201] I> hdmi cable connected
[0002.203] W> set volts not configured for 'vdd-1v0'
[0002.205] W> set volts not configured for 'vdd-1v8-hs'
[0002.206] I> retrieved tmds range from prod_list_hdmi_soc
[0002.210] E> invalid display type
[0002.215] E> cannot find any other nvdisp nodes
[0002.230] I> edid read success
[0002.243] I> edid read success
[0002.243] I> width = 640, height = 480, frequency = 25174825
[0002.243] I> width = 1920, height = 1080, frequency = 148500000
[0002.244] I> width = 1360, height = 768, frequency = 84750000
[0002.244] I> width = 1920, height = 1080, frequency = 148500000
[0002.245] I> width = 1920, height = 1080, frequency = 148351648
[0002.255] I> width = 1920, height = 1080, frequency = 74175824
[0002.260] I> width = 1920, height = 1080, frequency = 74175824
[0002.266] I> width = 1920, height = 1080, frequency = 74175824
[0002.272] I> width = 1280, height = 720, frequency = 74175824
[0002.277] I> width = 1280, height = 720, frequency = 74175824
[0002.283] I> width = 720, height = 576, frequency = 26973026
[0002.289] I> width = 720, height = 480, frequency = 26973026
[0002.294] I> width = 640, height = 480, frequency = 25174825
[0002.300] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.309] I> hdmi_enable, starting HDMI initialisation
[0002.315] I> hdmi_enable, HDMI initialisation complete
[0002.325] I> Load in CBoot Boot Options partition and parse it
[0002.331] E> Error -9 when finding node with path /boot-configuration
[0002.332] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.335] I> Using default boot order
[0002.338] I> boot-dev-order :-
[0002.341] I> 1.sd
[0002.343] I> 2.usb
[0002.345] I> 3.nvme
[0002.347] I> 4.emmc
[0002.349] I> 5.net
[0002.351] I> Hit any key to stop autoboot:	4	3	2	1
[0004.358] initializing target
[0004.358] calling apps_init()
[0004.359] starting app kernel_boot_app
[0004.378] I> found decompressor handler: lz4-legacy
[0004.379] I> decompressing BMP blob ...
[0004.390] I> Kernel type = Normal
[0004.390] I> ########## SD (0) boot ##########
[0004.391] I> Found sdcard
[0004.393] I> enabling 'vdd-sdmmc1-sw' regulator
[0004.397] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.557] I> sdmmc SDR mode
[0004.571] I> -0 params source =
[0004.581] I> Found 11 partitions in SDCARD (instance 0)
[0004.582] I> Look for boot partition
[0004.582] I> Fallback: assuming 0th partition is boot partition
[0004.589] I> Detect filesystem
[0004.610] I> Loading kernel-bootctrl from partition
[0004.610] I> Loading partition kernel-bootctrl at 0xa4ae0000 from device(0x6)
[0004.634] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.635] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.635] I> Loading extlinux.conf ...
[0004.636] I> Loading extlinux.conf binary from rootfs ...
[0004.636] I> rootfs path: /sd/boot/extlinux/extlinux.conf
[0004.666] I> Loading extlinux.conf sig file from rootfs ...
[0004.666] I> rootfs path: /sd/boot/extlinux/extlinux.conf.sig
[0004.683] I> Validate extlinux.conf ...
[0004.683] I> T19x: Authenticate extlinux.conf (bin_type: 54), max size 0x2000
[0004.684] I> Encryption fuse is not ON
[0004.684] I> L4T boot options
[0004.684] I> [1]: "primary kernel"
[0004.684] I> Enter choice:
[0007.686] I> Continuing with default option: 1
[0007.686] I> Loading kernel ...
[0007.686] I> Loading kernel binary from rootfs ...
[0007.686] I> rootfs path: /sd/boot/Image
[0010.501] I> Loading kernel sig file from rootfs ...
[0010.501] I> rootfs path: /sd/boot/Image.sig
[0010.513] I> overload load_size to 34484232 (from 34484240)
[0010.514] I> Validate kernel ...
[0010.514] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.828] I> Encryption fuse is not ON
[0010.843] I> Loading kernel-dtb ...
[0010.843] I> No kernel-dtb binary path
[0010.844] I> Continue to load from partition ...
[0010.844] W> No valid slot number is found in scratch register
[0010.844] W> Return default slot: _a
[0010.845] I> A/B: bin_type (38) slot 0
[0010.845] I> Loading kernel-dtb from partition
[0010.846] I> Loading partition kernel-dtb at 0x91000000 from device(0x6)
[0010.896] I> Validate kernel-dtb ...
[0010.896] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.899] I> Encryption fuse is not ON
[0010.900] I> Loading ramdisk from rootfs ...
[0010.900] I> Loading ramdisk binary from rootfs ...
[0010.901] I> rootfs path: /sd/boot/initrd
[0011.504] I> Loading ramdisk sig file from rootfs ...
[0011.504] I> rootfs path: /sd/boot/initrd.sig
[0011.516] I> overload load_size to 7238344 (from 7238352)
[0011.517] I> Validate ramdisk ...
[0011.517] I> T19x: Authenticate ramdisk (bin_type: 54), max size 0x4000000
[0011.583] I> Encryption fuse is not ON
[0011.591] I> Kernel hdr @0xa4ae0000
[0011.591] I> Kernel dtb @0x90000000
[0011.591] I> decompressor handler not found
[0011.592] I> Copying kernel image (34484232 bytes) from 0xa4ae0000 to 0x80080000 ... [0011.598] I> Done
[0011.599] I> Updated bpmp info to DTB
[0011.600] I> Ramdisk: Base: 0x92000000; Size: 0x6e72c8
[0011.600] I> Updated initrd info to DTB
[0011.600] W> WARN: Fail to override "console=none" in commandline
[0011.604] I> Active rootfs suffix:
[0011.607] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0011.614] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0011.622] W> No valid slot number is found in scratch register
[0011.627] W> Return default slot: _a
[0011.631] I> Active slot suffix:
[0011.634] I> add_boot_slot_suffix: slot_suffix =
[0011.638] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06aa000 lut_mem=0x2008@0xa06a5000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0011.668] I> Updated bootarg info to DTB
[0011.672] W> MAC addr invalid!
[0011.675] E> Failed to get WIFI MAC address
[0011.679] W> MAC addr invalid!
[0011.681] E> Failed to get Bluetooth MAC address
[0011.686] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:30:06:a9
[0011.693] W> "plugin-manager" doesn't exist, creating
[0011.697] I> Adding /chosen/plugin-manager/cvm
[0011.701] W> "chip-id" doesn't exist, creating
[0011.705] I> Adding /chosen/plugin-manager/chip-id
[0011.710] W> "configs" doesn't exist, creating
[0011.714] I> Adding /chosen/plugin-manager/configs
[0011.719] W> "ids" doesn't exist, creating
[0011.723] I> Adding /chosen/plugin-manager/ids
[0011.728] W> "odm-data" doesn't exist, creating
[0011.732] I> Adding /chosen/plugin-manager/odm-data
[0011.739] W> "memory" doesn't exist, creating
[0011.741] I> [0] START: 0x80000000, END: 0xac000000
[0011.745] I> [1] START: 0xac004000, END: 0xf0ad0000
[0011.750] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0011.755] I> dram_block larger than 80000000
[0011.759] I> [3] START: 0x100000000, END: 0x880000000
[0011.764] I> added [base:0x80000000, size:0x2c000000] to /memory
[0011.770] I> added [base:0xac200000, size:0x44800000] to /memory
[0011.775] I> added [base:0x100000000, size:0x780000000] to /memory
[0011.782] I> Updated memory info to DTB
[0011.785] E> add_disp_param: failed to get display params for du=1
[0011.791] W> "reset" doesn't exist, creating
[0011.796] I> Adding ecid(00000001647c98800800000008010300) to DT
[0011.801] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0011.806] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0011.811] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0011.815] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0011.820] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0011.825] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0011.830] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0011.834] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0011.840] W> "misc-data" doesn't exist, creating
[0011.843] I> Boot-device: eMMC
[0011.846] I> Add boot-sdmmc to plugin-manager/misc-data
[0011.852] I> Add storage-sdmmc to plugin-manager/misc-data
[0011.857] W> Unknown storage device
[0011.860] I> Add serial number:1424520037871 as DT property
[0011.866] I> Plugin-manager override starting
[0011.870] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0011.877] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0011.884] I> Disable plugin-manager status in FDT
[0011.886] I> Plugin-manager override finished successfully
[0011.891] I> tegrabl_load_kernel_and_dtb: Done
[0011.915] I> Kernel EP: 0x80080000, DTB: 0x90000000
ÿâ
ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
ÿâ
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
ec_mrq initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
mrq initialized
ÿá
[0001.135] I> Welcome to Cboot
ÿâfmon_post initialized
ÿá[0001.135] I> Cboot Version: t194-cfa2bc91
[0001.136] I>  0) Base:0x00000000 Size:0x00000000
[0001.144] I>  2) Base:0xf2000000 Size:0x00200000
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
ÿá[0001.157] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.236] I>  6) Base:0xf3800000 Size:0x00400000
[0001.272] I> 14) Base:0x40048000 Size:0x00002000ÿâemc_debugfs initialized
ÿá
[0001.281] I> 15) Base:0xac000000 Size:0x00004000ÿâfmon_debugfs initialized
mail_fs initialized
profile initialized
mods initialized
dt_fs initialized
initializing target
calling apps_init()
starting app shell
] ÿá
[0001.332] I> 16) Base:0x4004a000 Size:0x00002000
[0001.359] I> 22) Base:0x00000000 Size:0x00000000
[0001.417] I> 35) Base:0xab000000 Size:0x01000000
[0001.472] calling constructors
[0001.556] E> failed to read label property for node 227416: 13
[0001.561] E> failed to read label property for node 227452: 13
[0001.868] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.959] I> Plugin-manager override starting
[0001.964] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.995] I> Disable plugin-manager status in FDT
[0001.995] I> Plugin-manager override finished successfully
[0001.996] I> gpio framework initialized
[0002.058] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.072] I> fixed regulator driver initialized
[0002.084] I> register 'maxim' power off handle
[0002.085] I> virtual i2c enabled
[0002.085] I> registered 'maxim,max20024' pmic
[0002.096] I> Boot_device: SDMMC_BOOT instance: 3
[0002.105] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0002.121] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.172] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.194] I> enabling 'vdd-hdmi-5v0' regulator
[0002.200] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.200] I> hdmi cable connected
[0002.202] W> set volts not configured for 'vdd-1v0'
[0002.205] I> retrieved tmds range from prod_list_hdmi_soc
[0002.288] I> width = 720, height = 480, frequency = 26973026
[0002.299] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.341] I> 1.sd
[0002.343] I> 2.usb
[0002.349] I> 5.net
[0004.390] I> Found sdcard
[0004.398] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.558] I> sdmmc SDR mode
[0004.572] I> -0 params source =
[0004.582] I> Found 11 partitions in SDCARD (instance 0)
[0004.583] I> Look for boot partition
[0004.583] I> Fallback: assuming 0th partition is boot partition
[0004.611] I> Loading partition kernel-bootctrl at 0xa4ae0000 from device(0x6)
[0004.635] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.636] I> Loading extlinux.conf ...
[0004.637] I> rootfs path: /sd/boot/extlinux/extlinux.conf
[0004.667] I> rootfs path: /sd/boot/extlinux/extlinux.conf.sig
[0004.684] I> T19x: Authenticate extlinux.conf (bin_type: 54), max size 0x2000
[0004.685] I> [1]: "primary kernel"
[0004.685] I> Enter choice:
[0010.859] I> Loading kernel-dtb ...
[0010.912] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0011.519] I> Loading ramdisk sig file from rootfs ...
[0011.532] I> overload load_size to 7238344 (from 7238352)
[0011.599] I> Encryption fuse is not ON
[0011.613] I> decompressor handler not found
[0011.624] I> Updated bpmp info to DTB
[0011.625] I> Ramdisk: Base: 0x92000000; Size: 0x6e72c8
[0011.626] W> WARN: Fail to override "console=none" in commandline
[0011.636] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0011.649] W> Return default slot: _a
[0011.660] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06aa000 lut_mem=0x2008@0xa06a5000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0011.696] E> Failed to get WIFI MAC address
[0011.700] W> MAC addr invalid!
[0011.703] E> Failed to get Bluetooth MAC address
[0011.727] I> Adding /chosen/plugin-manager/chip-id
[0011.732] W> "configs" doesn't exist, creating
[0011.736] I> Adding /chosen/plugin-manager/configs
[0011.749] W> "odm-data" doesn't exist, creating
[0011.767] I> [1] START: 0xac004000, END: 0xf0ad0000
[0011.791] I> added [base:0xac200000, size:0x44800000] to /memory
[0011.797] I> added [base:0x100000000, size:0x780000000] to /memory
[0011.807] E> add_disp_param: failed to get display params for du=1
[0011.813] W> "reset" doesn't exist, creating
[0011.823] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0011.837] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0011.851] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0011.856] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0011.865] I> Boot-device: eMMC
[0011.868] I> Add boot-sdmmc to plugin-manager/misc-data
[0011.873] I> Add storage-sdmmc to plugin-manager/misc-data
[0011.882] I> Add serial number:1424520037871 as DT property
[0011.888] I> Plugin-manager override starting
[0011.913] I> tegrabl_load_kernel_and_dtb: Done
[0011.935] I> Kernel EP: 0x80080000, DTB: 0x90000000
Can you remove the “quiet” inside /boot/extlinux/extlinux.conf and dump the log again?
By default the kernel log is in silent mode so uart will only print partial logs.
Also, are you trying to boot from sdcard? Or you don’t know that your board is booting from sdcard?
Hi Wayne, thanks for replying.
I attempted a re-flash of 4.6 and now everything seems to be working well.
We were booting from SD both times, and it is the same card.
If the error appears again I will change the boot params and take the noisy bootlogs for you.
