Agx xavier eqos to sja1105Q switch
We replaced the original phy with Nxp SJA1105Q to expand Ethernet port
Basically this thread looks similar with our case
https://forums.developer.nvidia.com/t/about-xavier-eqos-mac-to-mac/124451
I checked switch driver ,it looks spi initialization is good.
I can see tx packet count increment both side (Agx and PC which connect to one slave port of switch), but no rx packet counting
and I try to ping between two slave port, not luck on ethernet working.
I wanna double check whether two slave port communication has nothing to do with Agx Xavier after switch is well configured with spi ,Am I right?
Any other debug hints?
Thanks a lot!
Actually, we don’t have experience with switch on SPI case. Many other users can share their experience here.
ok, I’m still debugging,
I found the following extran log in dmesg compared to original Agx xaviar system log. as I know we didn’t touch eqos driver.
and I don’t know what car reset here exactly mean, could you help figure out what might happen?
'/* issue CAR reset to device */
ret = hw_if->car_reset(pdata);
if (ret < 0) {
dev_err(&dev->dev, “Failed to reset MAC\n”);
return -ENODEV;
@leexye
Would you mind to share your connection diagram to help understand your case?
Yes, if your SPI driver setup as expected, it should work and nothing required anymore from AGX Xavier side.
SCHEMATIC1 _ 33_Enet_Architectu.pdf (51.9 KB)
I attached schematic in pdf format,thanks for your response. @alanz
Pls also share the dts file.
ether_qos@2490000 {
		/* PTP_ref clock speed in MHz */
		nvidia,ptp_ref_clock_speed = <312500000>;
		/* rxq_enable_ctrl = <rx0 rx1 rx2 rx3>
		 * 0x0 = Not enabled, 0x1 = Enabled for AV
		 * 0x2 = Enabled for Legacy, 0x3 = Reserved
		nvidia,rxq_enable_ctrl = <2 2 2 2>;
		nvidia,queue_prio = <0 1 2 3>;
		nvidia,use_tagged_ptp;
		nvidia,ptp_dma_ch = <3>;
		nvidia,chan_napi_quota = <64 64 64 64>;
		nvidia,pause_frames = <0>; /*0=enable, 1=disable */
		nvidia,phy-reset-gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(G, 5) 0>;
		nvidia,phy0-reset-gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(T, 3) 0>;
		nvidia,phy1-reset-gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(T, 5) 0>;
		nvidia,phy7-reset-gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(S, 6) 0>;
		nvidia,phy-max-frame-size = <16>;	/* size in kbytes */
		nvidia,eth_iso_enable = <1>; /*0=enable, 1=disable */
		phy-mode = "rgmii-id";
		nvidia,eqos_auto_cal_config_0_reg = <0x20010103>;
		resets = <0x5 0x11>;
		reset-names = "eqos_rst";
		fixed-link {
			speed=<1000>;
			full-duplex;
		mdio {
			compatible = "nvidia,eqos-mdio";
			#address-cells = <1>;
			#size-cells = <0>;
			phy0: ethernet-phy@0 {
				reg = <0>;
				interrupt-parent = <&tegra_main_gpio>;
				interrupts = <TEGRA194_MAIN_GPIO(T, 0) IRQ_TYPE_LEVEL_LOW>;
				nvidia,phy-reset-gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(T, 3) 0>;
				marvell,copper-mode;
				/* Setup LED[2] as interrupt pin (active low) */
				marvell,reg-init = <0x03 0x12 0x7fff 0x880>;
			phy1: ethernet-phy@1 {
				reg = <1>;
				interrupts = <TEGRA194_MAIN_GPIO(T, 4) IRQ_TYPE_LEVEL_LOW>;
				nvidia,phy-reset-gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(T, 5) 0>;
			phy7: ethernet-phy@7 {
				compatible = "ethernet-phy-ieee802.3-c45";
				reg = <0x7>;
				interrupts = <TEGRA194_MAIN_GPIO(T, 6) IRQ_TYPE_LEVEL_LOW>;
				nvidia,phy-reset-gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(S, 6) 0>;
				/* marvell,reg-init = <0x03 0x12 0x7fff 0x880>; */
spi@3210000 {
		status = "okay";
		sja1105p@0 {
			compatible = "nxp,sja1105p-switch";
			firmware_name = "sja1105p-1_cfg.bin";
			spi-max-frequency = <12000000>;
			spi-cpha;
			reg = <0x0>;
			port-0 {
				is-host = <0x0>;
				null-phy = <0x0>;
				phy-ref = <&phy7>;
			port-1 {
				is-host = <0x0>;
				null-phy = <0x0>;
				phy-ref = <&phy0>;
			port-2 {
				is-host = <0x0>;
				null-phy = <0x0>;
				phy-ref = <&phy1>;
			port-3 {
				is-host = <0x0>;
				null-phy = <0x1>;
				phy-ref = <0x0>;
			port-4 {
				is-host = <0x1>;
				null-phy = <0x1>;
				phy-ref = <0x0>;
				rx-delay = < 810 >;
				tx-delay = < 810 >;
		spi@1 {
			compatible = "spidev";
			reg = <0x1>;
			spi-max-frequency = <33000000>;
			controller-data {
				nvidia,enable-hw-based-cs;
				nvidia,rx-clk-tap-delay = <0x11>;
