Actually linuxdev and I are talking about the similar issue here. You need a dual-boot system to boot into ubuntu and then you could use the flash.sh to flash your board…
@WayneWWW Awesome, thanks for pointing that out! I’ll proceed to setting up a dual-boot, after I’ve freed some memory on my disk.
@WayneWWW @linuxdev I have tried dual booting my Windows and used SDK Manager to flash and install packages on my AGX Xavier, and its a success!
Most of the time was spent trying to set up dual boot and making space for shrinkage of the disk on Windows 10. Had to turn off hibernation, search indexing, virtual memory, etc so that I could shrink out 55GB disk space.
All seems fine on my Xavier at the moment, CUDA Toolkit 10.0 is up and the configurations seem fine!
Thank you all so much for the continuous support thus far and do let me know if you require any input for this matter. :)
32.1可以使用cpu调速吗
Please file a new topic in English. Thanks.
Pls refer to the nvpmodel tools for dynamic config.
B&R
Alan
nx开发套件 can口如何使用呢,是sd卡启动那个
Hi junxing.liang,
Your problem is not related to this topic.
Please file a new topic for it and please write in English.
I have the same issue on a native ubuntu host.
