In which source code to add print to test the hardware, there is a problem in that device. I only have the source code of kernel and CBOOT. You said it didn’t enter CBOOT. I don’t know which source code to debug,it is difficult to find the problem by comparing the design guidance
I saw that the boot was stopped in “failed: thermal config”, and “failed: Memio rail config” will be printed after the normal process. May there be a problem in the hardware design, can you provide me with a direction?
Hi, the log does not provide much info about issue. You’d better to follow the checklist in product design guide to check your schematic design, or compare your board design to that of devkit (P2822) to find out the difference.
In the first box, I don’t understand what “module pins” are and what “w / SOC ram_code [1:0] strapping pins” are
In the second box, I don’t understand what “module pin” are and what “Boot strapping pin” are
I have confirmed with the supplier TI. For the time being, there is only the document of the second picture. I just want to confirm that these two pictures are the same chip
