AGX Xavier Shared memory transfer large files
I’m facing AGX Xavier PCIe communication issue between two Xavier(Endpoint & Rootport system).
How to test the transfer rate of large files, In shared page of RAM mode,
JetPack version is JetPack_5.1.1 and Jetson Linux is 35.2.1.
Have you checked PCIe Endpoint Mode — Jetson Linux Developer Guide documentation (nvidia.com) ?
Endpoint mode is can work normally.
I mean is how to test transfer rate, or how to transfer large files In shared page of RAM mode.
maybe check the Custom Endpoint Function Driver section in the document.
Don’t we have a test program available?
In PCIe Endpoint Mode, How to achieve without reboot the root device, lspci can find EP device ?
