Hello, Nvidia:
On the carrier board we made ourselves, we upgraded Xavier to JP5.1.1, but now we find that it occasionally fails to boot normally, which does not exist on JP4.6.1, so I would like you to help me analyze it. The following is the serial port log of normal startup and non-normal startup. jp511_startup_failed.txt (10.9 KB) jp511_startup_ok.txt (78.2 KB)
I’ve diff both of your logs.
The most difference is about the temperature.
[0000.209] I> Temperature = 39000
The boot up seems failed in UEFI.
Could you help to use debug UEFI to enable the log and share it for further check?
You could refer to the following instruction to setup and build debug uefi binary. (uefi_Jetson_DEBUG.bin). Build without docker · NVIDIA/edk2-nvidia Wiki · GitHub
