The whole log is as follows:
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.449] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-938a8cd8)
[0000.450] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.450] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.451] E> DEVICE_PROD: Invalid value data = 70030000, size = 0.
[0000.457] W> device prod register failed
[0000.461] I> Boot-device: QSPI
[0000.464] I> Boot_device: QSPI_FLASH instance: 0
[0000.469] I> QSPI Flash Size = 64 MB
[0000.472] I> Qspi initialized successfully
[0000.475] I> qspi flash-0 params source = boot args
[0000.796] I> sdmmc DDR50 mode
[0000.797] I> sdmmc-3 params source = safe params
[0000.802] I> Found 50 partitions in QSPI_FLASH (instance 0)
[0000.804] W> Cannot find any partition table for 00000003
[0000.808] I> Found 11 partitions in SDMMC_USER (instance 3)
[0000.809] I> Staged scrubbing
[0001.018] W> No valid slot number is found in scratch register
[0001.018] W> Return default slot: _a
[0001.019] I> Active Boot chain : 0
[0001.019] I> parsing oem signed section of sce header done
[0001.020] I> sce binary init read from storage
[0001.021] I> oem authentication of sce header done
[0001.026] I> sce binary done read from storage
[0001.027] I> sce: Authentication init Done
[0001.028] I> parsing oem signed section of bpmp-fw header done
[0001.033] I> bpmp-fw binary init read from storage
[0001.038] I> Loading SCE-FW …
[0001.041] I> sce: Authentication Finalize Done
[0001.046] I> oem authentication of bpmp-fw header done
[0001.060] I> bpmp-fw binary done read from storage
[0001.060] I> bpmp-fw: Authentication init Done
[0001.061] I> parsing oem signed section of cpubl header done
[0001.065] I> cpubl binary init read from storage
[0001.069] I> bpmp-fw: Authentication Finalize Done
[0001.074] I> oem authentication of cpubl header done
[0001.082] I> cpubl binary done read from storage
[0001.083] I> cpubl: Authentication init Done
[0001.088] I> parsing oem signed section of rce header done
[0001.093] I> rce binary init read from storage
[0001.097] I> Relocating BR-BCT
[0001.100] I> cpubl: Authentication Finalize Done
[0001.104] I> oem authentication of rce header done
[0001.109] I> rce binary done read from storage
[0001.113] I> rce: Authentication init Done
[0001.117] I> parsing oem signed section of ape header done
[0001.122] I> ape binary init read from storage
[0001.127] I> rce: Authentication Finalize Done
[0001.131] I> oem authentication of ape header done
[0001.136] I> ape binary done read from storage
[0001.140] I> ape: Authentication init Done
[0001.144] I> parsing oem signed section of tos header done
[0001.149] I> tos binary init read from storage
[0001.153] I> ape: Authentication Finalize Done
[0001.158] I> oem authentication of tos header done
[0001.165] I> tos binary done read from storage
[0001.167] I> tos: Authentication init Done
[0001.171] I> parsing oem signed section of bpmp-fw-dtb header done
[0001.177] I> bpmp-fw-dtb binary init read from storage
[0001.182] I> tos: Authentication Finalize Done
[0001.188] I> oem authentication of bpmp-fw-dtb header done
[0001.191] I> bpmp-fw-dtb binary done read from storage
[0001.196] I> bpmp-fw-dtb: Authentication init Done
[0001.201] I> parsing oem signed section of cpubl-dtb header done
[0001.207] I> cpubl-dtb binary init read from storage
[0001.211] I> bpmp-fw-dtb: Authentication Finalize Done
[0001.247] I> oem authentication of cpubl-dtb header done
[0001.248] I> cpubl-dtb binary done read from storage
[0001.248] I> cpubl-dtb: Authentication init Done
[0001.249] I> parsing oem signed section of eks header done
[0001.250] I> eks binary init read from storage
[0001.251] I> cpubl-dtb: Authentication Finalize Done
[0001.252] I> oem authentication of eks header done
[0001.255] I> eks binary done read from storage
[0001.260] I> eks: Authentication init Done
[0001.264] I> eks: Authentication Finalize Done
[0001.268] I> EKB detected (length: 0x410) @ VA:0x5270a400
[0001.279] I> Unhalting SCE
▒▒NOTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:15:32, Jul 26 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 315: key_mgnt_processing …
hwkey-agent: 223: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
[1279530] : [ LOG ] : L4T Sce Booted : 1.4.0▒▒
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku_init: not sku 00
sku_init: not sku 98
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
spi2 has invalid initial rate (14836364)
392 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0001.661] I> Welcome to Cboot
▒▒fmon_post initialized
▒▒[0001.661] I> Cboot Version: t194-3dbcb79a
[0001.662] I> CPU-BL Params @ 0x772830000
[0001.662] I> 0) Base:0x00000000 Size:0x00000000
[0001.665] I> 1) Base:0x771100000 Size:0x00100000
[0001.670] I> 2) Base:0x772000000 Size:0x00200000
[0001.674] I> 3) Base:0x771200000 Size:0x00200000
[0001.679] I> 4) Base:0x771000000 Size:0x00100000
▒▒clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ▒▒[0001.684] I> 5) Base:0x770f00000 Size:0x00100000
[0001.803] I> 6) Base:0x773800000 Size:0x00400000
[0001.808] I> 7) Base:0x771c00000 Size:0x00400000
[0001.812] I> 8) Base:0x770e00000 Size:0x00100000
[0001.817] I> 9) Base:0x770d00000 Size:0x00100000
[0001.821] I> 10) Base:0x773000000 Size:0x00800000
[0001.826] I> 11) Base:0x40000000 Size:0x00040000
[0001.830] I> 12) Base:0x770c00000 Size:0x00100000
[0001.835] I> 13) Base:0x40046000 Size:0x00002000
[0001.839] I> 14) Base:0x40048000 Size:0x00002000
[0001.844] I> 15) Base:0xac000000 Size:0x00004000
[0001.848] I> 16) Base:0x4004a000 Size:0x00002000
[0001.853] I> 17) Base:0x770b00000 Size:0x00100000
[0001.857] I> 18) Base:0x4004c000 Size:0x00002000
[0001.862] I> 19) Base:0x772200000 Size:0x00600000
[0001.866] I> 20) Base:0x4004e000 Size:0x00002000
[0001.871] I> 21) Base:0x770ad0000 Size:0x0000c000
[0001.875] I> 22) Base:0x00000000 Size:0x00000000
[0001.880] I> 23) Base:0x770ae0000 Size:0x00020000
[0001.884] I> 24) Base:0x776000000 Size:0x02000000
[0001.889] I> 25) Base:0x40050000 Size:0x00002000
[0001.893] I> 26) Base:0x40040000 Size:0x00006000
[0001.898] I> 27) Base:0x771800000 Size:0x00400000
[0001.902] I> 28) Base:0x774c00000 Size:0x01400000
[0001.907] I> 29) Base:0x771400000 Size:0x00400000
[0001.911] I> 30) Base:0x00000000 Size:0x00000000
[0001.916] I> 31) Base:0x00000000 Size:0x00000000
[0001.920] I> 32) Base:0x778000000 Size:0x08000000
[0001.925] I> 33) Base:0x00000000 Size:0x00000000
[0001.929] I> 34) Base:0x773c00000 Size:0x01000000
[0001.934] I> 35) Base:0xab000000 Size:0x01000000
[0001.938] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.943] I> 37) Base:0x772800000 Size:0x00800000
[0001.947] I> 38) Base:0x80000000 Size:0x20000000
[0001.952] I> 39) Base:0xb0000000 Size:0x08000000
[0001.956] I> 40) Base:0x00000000 Size:0x00000000
[0001.961] I> 41) Base:0x00000000 Size:0x00000000
[0001.965] I> 42) Base:0x00000000 Size:0x00000000
[0001.970] I> 43) Base:0x00000000 Size:0x00000000
[0001.974] I> 44) Base:0x00000000 Size:0x00000000
[0001.978] I> 45) Base:0x00000000 Size:0x00000000
[0001.983] GIC-SPI Target CPU: 0
[0001.986] Interrupts Init done
[0001.989] calling constructors
[0001.992] initializing heap
[0001.994] I> Heap: [0xa06945e8 … 0xab000000]
[0001.999] initializing threads
[0002.002] initializing timers
[0002.004] creating bootstrap completion thread
[0002.009] top of bootstrap2()
[0002.011] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0002.016] initializing platform
[0002.334] I> dram scrub successful
[0002.334] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0002.335] W> device prod register failed
[0002.335] I> Bl_dtb @0xaaf00000
[0002.339] W> “plugin-manager” doesn’t exist, creating
[0002.339] W> “ids” doesn’t exist, creating
[0002.340] W> “connection” doesn’t exist, creating
[0002.341] W> “configs” doesn’t exist, creating
[0002.348] I> Find /i2c@3160000’s alias i2c0
[0002.348] I> Reading eeprom i2c=0 address=0x50
[0002.376] I> Device at /i2c@3160000:0x50
[0002.376] I> Reading eeprom i2c=0 address=0x56
[0002.377] E> I2C: slave not found in slaves.
[0002.377] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0002.378] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.378] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0002.386] E> eeprom: Failed to read I2C slave device
[0002.391] I> Eeprom read failed 0x3526070d
[0002.396] I> Find /i2c@3180000’s alias i2c2
[0002.399] I> Reading eeprom i2c=2 address=0x54
[0002.404] E> I2C: slave not found in slaves.
[0002.407] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0002.415] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.420] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0002.430] E> eeprom: Failed to read I2C slave device
[0002.435] I> Eeprom read failed 0x3526070d
[0002.439] I> Reading eeprom i2c=2 address=0x57
[0002.443] E> I2C: slave not found in slaves.
[0002.447] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0002.455] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.460] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0002.470] E> eeprom: Failed to read I2C slave device
[0002.475] I> Eeprom read failed 0x3526070d
[0002.479] I> Reading eeprom i2c=2 address=0x52
[0002.483] E> I2C: slave not found in slaves.
[0002.487] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.495] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.501] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0002.510] E> eeprom: Failed to read I2C slave device
[0002.515] I> Eeprom read failed 0x3526070d
[0002.520] I> Find /i2c@c240000’s alias i2c1
[0002.523] I> Reading eeprom i2c=1 address=0x52
[0002.529] E> I2C: slave not found in slaves.
[0002.531] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.539] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.545] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.554] E> eeprom: Retry to read I2C slave device.
[0002.559] E> I2C: slave not found in slaves.
[0002.563] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.571] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.576] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.586] E> eeprom: Failed to read I2C slave device
[0002.591] I> Eeprom read failed 0x3526070d
[0002.595] I> Reading eeprom i2c=1 address=0x50
[0002.599] E> I2C: slave not found in slaves.
[0002.603] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.611] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.617] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.626] E> eeprom: Retry to read I2C slave device.
[0002.631] E> I2C: slave not found in slaves.
[0002.635] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.643] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.648] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.658] E> eeprom: Failed to read I2C slave device
[0002.663] I> Eeprom read failed 0x3526070d
[0002.667] I> create_pm_ids: id: 2888-0008-600-E, len: 15
[0002.672] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.683] I> Adding plugin-manager/ids/2888-0008-600=/i2c@3160000:module@0x50
[0002.690] W> “i2c@3160000” doesn’t exist, creating
[0002.695] W> “module@0x50” doesn’t exist, creating
[0002.701] I> Adding plugin-manager/cvm
[0002.703] W> “chip-id” doesn’t exist, creating
[0002.707] I> Adding plugin-manager/chip-id/A02P
[0002.712] I> Plugin-manager override starting
[0002.717] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.726] I> node /plugin-manager/fragement-soft-wdt matches
[0002.733] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.737] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.748] I> Disable plugin-manager status in FDT
[0002.748] I> Plugin-manager override finished successfully
[0002.749] I> gpio framework initialized
[0002.754] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0002.761] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0002.767] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.775] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.783] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.789] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.795] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.803] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.811] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.817] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.825] I> fixed regulator driver initialized
[0002.837] I> register ‘maxim’ power off handle
[0002.837] I> virtual i2c enabled
[0002.838] I> registered ‘maxim,max20024’ pmic
[0002.839] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.846] I> Boot-device: QSPI
[0002.849] I> Boot_device: QSPI_FLASH instance: 0
[0002.854] I> QSPI source rate = 204000 Khz
[0002.857] I> Requested rate for QSPI clock = 34000 Khz
[0002.862] I> BPMP-set rate for QSPI clk = 34000 Khz
[0002.867] I> QSPI Flash Size = 64 MB
[0002.872] I> Qspi initialized successfully
[0002.874] I> qspi flash-0 params source = boot args
[0002.879] I> create_pm_ids: id: 2888-0008-600-E, len: 15
[0002.884] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.899] I> sdmmc-3 params source = safe params
[0002.901] I> Found 50 partitions in QSPI_FLASH (instance 0)
[0002.921] W> Cannot find any partition table for 00000003
[0002.933] I> Found 11 partitions in SDMMC_USER (instance 3)
[0002.944] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.949] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.950] I> hdmi cable connected
[0002.952] W> set volts not configured for ‘vdd-1v0’
[0002.954] W> set volts not configured for ‘vdd-1v8-hs’
[0002.959] E> invalid display type
[0002.963] E> invalid display type
[0002.964] E> cannot find any other nvdisp nodes
[0002.980] I> edid read success
[0002.992] I> edid read success
[0002.992] I> width = 640, height = 480, frequency = 25174825
[0002.993] I> width = 640, height = 480, frequency = 25174825
[0002.993] I> width = 1920, height = 1080, frequency = 148500000
[0002.994] I> width = 720, height = 480, frequency = 27000000
[0002.994] I> width = 1920, height = 1080, frequency = 148351648
[0002.998] I> width = 1280, height = 720, frequency = 74175824
[0003.004] I> width = 720, height = 480, frequency = 26973026
[0003.009] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0003.019] I> hdmi_enable, starting HDMI initialisation
[0003.024] I> hdmi_enable, HDMI initialisation complete
[0003.035] I> Load in CBoot Boot Options partition and parse it
[0003.036] I> boot-order :-
[0003.036] I> 1.emmc
[0003.036] I> tftp-server-ip: 192.168.0.1
[0003.039] W> parse_ip_info: static-ip info is not required, only tftp-server-ip is required.
[0003.047] W> Failed to parse GUID
[0003.051] I> boot-dev-order :-
[0003.054] I> 1.emmc
[0003.055] I> Hit any key to stop autoboot: 4 3 2 1
[0005.063] initializing target
[0005.063] calling apps_init()
[0005.064] starting app kernel_boot_app
[0005.074] I> found decompressor handler: lz4-legacy
[0005.075] I> decompressing BMP blob …
[0005.086] I> Kernel type = Normal
[0005.086] I> Loading kernel-bootctrl from partition
[0005.086] I> Loading partition kernel-bootctrl at 0xa4ad0000 from device(0x1)
[0005.094] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0005.095] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0005.095] I> ########## Fixed storage boot ##########
[0005.096] I> Already published: 00010003
[0005.098] I> Look for boot partition
[0005.102] I> Fallback: assuming 0th partition is boot partition
[0005.107] I> Detect filesystem
[0005.134] I> Loading extlinux.conf …
[0005.135] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.184] I> L4T boot options
[0005.184] I> [1]: “primary kernel”
[0005.184] I> [2]: “Custom Header Config: <HDR40 User Custom [2021-11-04-175459]>”
[0005.185] I> Enter choice:
[0006.335] I> Invalid option: d
[0006.335] I> Enter choice:
[0006.688] I> Invalid option: d
[0006.688] I> Enter choice:
[0017.158] I> Invalid option: e7
[0017.158] I> Enter choice:
[0023.653] I> Selected option: 1
[0023.654] I> Loading kernel sig file from rootfs …
[0023.654] I> rootfs path: /sdmmc_user/boot/Image.sig
[0023.679] I> Loading kernel binary from rootfs …
[0023.679] I> rootfs path: /sdmmc_user/boot/Image
[0024.099] I> overload load_size to 34484232 (from 34537480)
[0024.122] I> Validate kernel …
[0024.122] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0024.436] E> digest on binary did not match!!
[0024.437] C> OEM authentication of kernel payload failed!
[0024.437] W> Failed to validate kernel binary (err=1077936152, fail=0)
[0024.438] W> Security fuse not burned, ignore validation failure
[0024.445] I> No kernel-dtb binary path
[0024.445] W> No valid slot number is found in scratch register
[0024.446] W> Return default slot: _a
[0024.446] I> A/B: bin_type (38) slot 0
[0024.449] I> Loading kernel-dtb from partition
[0024.454] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0024.471] I> Validate kernel-dtb …
[0024.471] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0024.475] I> Encryption fuse is not ON
[0024.476] I> Loading ramdisk from rootfs …
[0024.478] I> Loading initrd sig file from rootfs …
[0024.483] I> rootfs path: /sdmmc_user/boot/initrd.sig
[0024.524] I> Loading initrd binary from rootfs …
[0024.525] I> rootfs path: /sdmmc_user/boot/initrd
[0024.641] I> overload load_size to 7238344 (from 7238352)
[0024.644] I> Validate initrd …
[0024.644] I> T19x: Authenticate initrd (bin_type: 49), max size 0x4000000
[0024.711] I> Encryption fuse is not ON
[0024.724] I> Kernel hdr @0xa4ad0000
[0024.724] I> Kernel dtb @0x90000000
[0024.724] I> decompressor handler not found
[0024.725] I> Copying kernel image (34484232 bytes) from 0xa4ad0000 to 0x80080000 … [0024.736] I> Done
[0024.737] I> Updated bpmp info to DTB
[0024.738] I> Ramdisk: Base: 0x92000000; Size: 0x6e72c8
[0024.738] I> Updated initrd info to DTB
[0024.739] W> WARN: Fail to override “console=none” in commandline
[0024.739] I> Active rootfs suffix:
[0024.740] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0024.748] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0024.755] W> No valid slot number is found in scratch register
[0024.760] W> Return default slot: _a
[0024.764] I> Active slot suffix:
[0024.767] I> add_boot_slot_suffix: slot_suffix =
[0024.772] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06a0000 lut_mem=0x2008@0xa069b000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0024.803] I> Updated bootarg info to DTB
[0024.807] W> MAC addr invalid!
[0024.810] E> Failed to get WIFI MAC address
[0024.814] W> MAC addr invalid!
[0024.816] E> Failed to get Bluetooth MAC address
[0024.821] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:55:b9:5b
[0024.828] W> “plugin-manager” doesn’t exist, creating
[0024.832] I> Adding /chosen/plugin-manager/cvm
[0024.836] W> “chip-id” doesn’t exist, creating
[0024.840] I> Adding /chosen/plugin-manager/chip-id
[0024.845] W> “configs” doesn’t exist, creating
[0024.849] I> Adding /chosen/plugin-manager/configs
[0024.854] W> “ids” doesn’t exist, creating
[0024.858] I> Adding /chosen/plugin-manager/ids
[0024.862] W> “odm-data” doesn’t exist, creating
[0024.867] I> Adding /chosen/plugin-manager/odm-data
[0024.874] W> “memory” doesn’t exist, creating
[0024.876] I> [0] START: 0x80000000, END: 0xac000000
[0024.880] I> [1] START: 0xac004000, END: 0x770ad0000
[0024.885] I> [2] START: 0x770adc000, END: 0x770ae0000
[0024.890] I> dram_block larger than 80000000
[0024.894] I> added [base:0x80000000, size:0x2c000000] to /memory
[0024.900] I> added [base:0xac200000, size:0x6c4800000] to /memory
[0024.907] I> Updated memory info to DTB
[0024.910] E> add_disp_param: failed to get display params for du=1
[0024.916] W> “reset” doesn’t exist, creating
[0024.920] I> Adding ecid(0000000164056082240000000dff8100) to DT
[0024.926] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0024.930] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0024.935] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0024.940] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0024.944] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0024.949] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0024.954] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0024.959] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0024.965] W> “misc-data” doesn’t exist, creating
[0024.968] I> Boot-device: QSPI
[0024.971] W> Unknown boot device
[0024.974] I> Add storage-qspi to plugin-manager/misc-data
[0024.979] W> Unknown storage device
[0024.983] I> Add serial number:1424021093729 as DT property
[0024.989] I> Plugin-manager override starting
[0024.993] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0025.000] I> node /plugin-manager/fragement-soft-wdt matches
[0025.007] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0025.012] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0025.024] I> Disable plugin-manager status in FDT
[0025.025] I> Plugin-manager override finished successfully
[0025.026] I> tegrabl_load_kernel_and_dtb: Done
[0025.048] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253 (root@waytous) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #15 SMP PREEMPT Tue Feb 22 18:12:06 CST 2022
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 6c4800000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a06a0000
[ 0.000000] Found lut_mem: 00002008@a069b000
[ 1.808535] tegra-xudc-new 3550000.xudc: extcon_get_extcon_dev_by_cable failed -19
[ 1.854237] ufs_tegra 2450000.ufshci: dme-link-startup: error code 1
[27717883] : [ LOG ] : dram_ecc enabled
[27718327] : [ LOG ] : dram-ecc init success
▒▒WARNING: pll_d3 has no dyn ramp
▒▒[ 1.970044] ufs_tegra 2450000.ufshci: dme-link-startup: error code 1
[ 2.082178] ufs_tegra 2450000.ufshci: dme-link-startup: error code 1
[ 2.092712] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 2.092772] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 2.194143] ufs_tegra 2450000.ufshci: dme-link-startup: error code 1
[ 2.206097] ufs_tegra 2450000.ufshci: link startup failed 1
[ 2.382808] CPU:0, Error:CBB-NOC@0x2300000,irq=494
[ 2.547451] **************************************
[ 2.547560] * For more Internal Decode Help
[ 2.547650] * http://nv/cbberr
[ 2.547726] * NVIDIA userID is required to access
[ 2.547825] **************************************
[ 2.547928] CPU:0, Error:CBB-NOC
[ 2.548001] Error Logger : 0
[ 2.548075] ErrLog0 : 0x80030000
[ 2.548154] Transaction Type : RD - Read, Incrementing
[ 2.548266] Error Code : SLV
[ 2.548339] Error Source : Target
[ 2.548422] Error Description : Target error detected by CBB slave
[ 2.629636] AXI2APB_1 bridge error: SFIFONE - Status FIFO Not Empty interrupt[ 2.629814] AXI2APB_1 bridge error: TIM - Timer(Timeout) interrupt
[ 2.629955] AXI2APB_4 bridge error: RDFIFOF - Read Response FIFO Full interrupt[ 2.630107] Packet header Lock : 0
[ 2.630188] Packet header Len1 : 3
[ 2.630269] NOC protocol version : version >= 2.7
[ 2.630374] ErrLog1 : 0x320024
[ 2.630447] ErrLog2 : 0x0
[ 2.630511] RouteId : 0x320024
[ 2.630587] InitFlow : ccroc_p2ps/I/ccroc_p2ps
[ 2.630693] Targflow : axis_satellite_grout/T/axis_satellite_grout
[ 2.630826] TargSubRange : 0
[ 2.630903] SeqId : 0
[ 2.630966] ErrLog3 : 0x2470088
[ 2.631040] ErrLog4 : 0x0
[ 2.631132] Address : 0x2470088 (unknown device)
[ 2.631235] ErrLog5 : 0x909f851
[ 2.631385] Non-Modify : 0x1
[ 2.631630] AXI ID : 0x12
[ 2.631882] Master ID : CCPLEX
[ 2.632127] Security Group(GRPSEC): 0x7e
[ 2.632456] Cache : 0x1 – Device
[ 2.632751] Protection : 0x2 – Unprivileged, Non-Secure, Data Access
[ 2.638288] FALCONSEC : 0x0
[ 2.641421] Virtual Queuing Channel(VQC): 0x0
[ 2.646058] **************************************
[ 2.651107] kernel BUG at /home/lzj/xavier/32.6.1/Linux_for_Tegra/source/public/kernel/nvidia/drivers/platform/tegra/tegra_cbb.c:839!
[ 2.662772] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 2.667851] Modules linked in:
[ 2.671032] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G S 4.9.253 #15
[ 2.678606] Hardware name: Jetson-AGXi (DT)
[ 2.682551] task: ffffff8009ea13c0 task.stack: ffffff8009e90000
[ 2.688501] PC is at tegra_cbb_error_isr+0x1a0/0x1a8
[ 2.693226] LR is at tegra_cbb_error_isr+0xc8/0x1a8
[ 2.698039] pc : [] lr : [] pstate: 604001c5
[ 2.705649] sp : ffffffc6f064abf0
[ 2.709329] x29: ffffffc6f064abf0 [ 2.711942] tegra_cec 3960000.tegra_cec: physical address: 20:00.
[ 2.718608] x28: 0000000000000005
[ 2.722280] x27: 00000000000001c0 x26: 0000000000000001
[ 2.728050] x25: ffffff800a1fc000 x24: ffffff8009846018
[ 2.733824] x23: ffffff800951f020 x22: 0000000000000001
[ 2.739279] x21: 00000000000001ee x20: ffffff800a048520
[ 2.745036] x19: ffffff800a048520 x18: 0000000000000010
[ 2.751971] x17: 0000000000000002 x16: 0000000000000003
[ 2.757912] x15: 0000000000000001 x14: ffffff808a17b5b7
[ 2.763695] x13: ffffff8009001fa8 x12: 00000000ffffffff
[ 2.769408] x11: 0000000000000020 x10: 0000000000000343
[ 2.775024] x9 : ffffff80135f9220 x8 : ffffff80083d6cf0
[ 2.780516] x7 : ffffff8009ee4468 x6 : 0000000000000000
[ 2.786270] x5 : 0000000000000000 x4 : 0000000000000000
[ 2.791629] x3 : ffffffffffffffff x2 : ffffff8009eb4220
[ 2.797241] x1 : ffffff8009ea13c0 x0 : 0000000000010101
[ 2.802550]
[ 2.804025] Process swapper/0 (pid: 0, stack limit = 0xffffff8009e90000)
[ 2.809158] Call trace:
[ 2.811530] [] tegra_cbb_error_isr+0x1a0/0x1a8
[ 2.817127] [] __handle_irq_event_percpu+0x68/0x288
[ 2.823249] [] handle_irq_event_percpu+0x28/0x60
[ 2.829111] [] handle_irq_event+0x50/0x80
[ 2.834450] [] handle_fasteoi_irq+0xd4/0x1c0
[ 2.839872] [] generic_handle_irq+0x34/0x50
[ 2.845211] [] __handle_domain_irq+0x68/0xc0
[ 2.850810] [] gic_handle_irq+0x5c/0xb0
[ 2.855886] [] el1_irq+0xe8/0x194
[ 2.860612] [] irq_exit+0xd0/0x118
[ 2.864815] [] __handle_domain_irq+0x6c/0xc0
[ 2.871112] [] gic_handle_irq+0x5c/0xb0
[ 2.876100] [] el1_irq+0xe8/0x194
[ 2.958820] [] cpuidle_enter_state+0xb8/0x380
[ 2.960296] [] cpuidle_enter+0x34/0x48
[ 2.961703] [] call_cpuidle+0x44/0x70
[ 2.963049] [] cpu_startup_entry+0x1b0/0x200
[ 2.964410] [] rest_init+0x84/0x90
[ 2.965746] [] start_kernel+0x374/0x38c
[ 2.967083] [] __primary_switched+0x80/0x94
[ 2.968414] —[ end trace 213a5b2942e30eab ]—
[ 2.976941] Kernel panic - not syncing: Fatal exception in interrupt
[ 2.978305] SMP: stopping secondary CPUs
[ 3.041065] Kernel Offset: disabled
[ 3.042396] Memory Limit: none
[ 3.043700] trusty-log panic notifier - trusty version Built: 12:20:34 Jul 26 2021 [ 3.050763] Rebooting in 5 seconds…
