We have developed a carrier board and are making use of Jetson AGX module. Our expectation is that AGXi should directly boot as we do with AGX module.
But I get some kernal trace logs as attached.
Kindly let me know the part to look into.
I have attached the working log too.
Can you try with AGX devkit carrier board? Reflash it with our SW to see if can work.
You can go to ~/nvidia on your host machine and find out the Linux_for_Tegra for t194, and then run command
