AI Aerial FAQ (3/6): Designing a Modular 6G System Using NVIDIA Aerial Framework
This is the third of six (3/6) posts serializing the FAQ report from the most recent NVIDIA 6G Developer Day (sessions playback here). All questions and answers are directly from attendees on the day and the answers provided to them.
The Sections are:
1/6: Introducing NVIDIA 6G Research & Development Portfolio
2/6: Prototyping 6G with the NVIDIA Sionna Research Kit
3/6: Designing a Modular 6G System Using NVIDIA Aerial Framework
4/6: Aerial Framework – Performant GPU-Accelerated Code From Python
5/6: Optimizing 6G Performance With CUDA and NVIDIA DOCA
6/6: Simulating 6G with NVIDIA Aerial Omniverse Digital Twin
The full FAQ report is here:
2025_6GDD_NVIDIA AI Aerial_FAQ.pdf (374.9 KB)
Q 3.1: In which part of Packet Scheduler do you see a place for AI?
A: This is an open area of research. Example topics include - user selection, user pairing for massive MIMO, link adaptation, etc.
Q 3.2: How long does it take to learn how to use Aerial Framework?
A: First place to start is with the tutorials and docs.
Q 3.3: Why pipelines and modules instead of some design patterns usage and components which might be developed by devs?
A: Pipelines and modules are just one example abstraction for building modular components with flexible interfaces so users can bring their own algorithms or use the reference algorithms.
Q 3.4: Why can you not use C code in place of Python in Aerial Framework?
A: You can use CUDA C/C++. The framework supports mixing Python-lowered modules with hand-written CUDA C++ kernels and plugins for performance or legacy code integration.
Q 3.5: Can Aerial Framework be used for other signal processing that is not 5G?
A: Yes
Q 3.6: In the AERIAL documentation, we read a statement: “Aerial support of AX800, A100X, A100, CX6-DX has reached End of Life.” Does this mean it’s impossible for us to use version 25.3 of AERIAL to achieve physical layer acceleration for the Openairinterface project on A100 GPUs.
A: EOL means NVIDIA is unable to provide support for user problems when using these components. All converged card and devkit (e.g. A100+CX6_DX) are no longer available from CICD and developer cluster, so it is not possible to confirm that they would work on the latest Aerial releases.
Q 3.7: Can we use Rust language with NVIDIA Aerial Framework?
A: No
Q 3.8: Will DGX Spark support Aerial Framework?
A: DGX Spark is supported.
Q 3.9: Individual modules can be lowered/accelerated and used to compose pipelines. While that is great, is there functionality available to integrate pipelines in a GPU-optimized way? Also, is pipeline parallelism available to accelerate GPU workloads?
A: Aerial Framework Pipelines allow mixing TensorRT engines lowered from Python, with CUDA C++ in modular and flexible manner.
Q 3.10: What are the HW specs for run time environment if someone is using a 3rd party server?
A: The Runtime environment currently requires a Grace Hopper (GH200) system.
Q 3.11: Do these ‘graphs’ run like nodes in a graph database? Trying to understand the way pipelines are defined and how the nodes exchange information to ensure compatibility.
A: Pipelines are Directed Acyclic Graphs (DAGs) of CUDA nodes, executed as CUDA Graphs, not a graph database.
Q 3.12: Does the pipelines use fixed-point or floating-point?
A: Floating point
Q 3.13: Do I have to code in CUDA as well or only in python?
A: CUDA and python are both supported.
Q 3.14: Does Aerial Framework work with codes written in MATLAB?
A: Matlab support is under consideration
Q 3.15: Is Aerial Framework compatible with Sionna (which uses Tensorflow)?
A: Not currently but it is being explored for future releases.
Q 3.16: Can the notebooks be run on Google Colab?
A: Notebooks require a GPU and a Docker environment with NVIDIA Container Toolkit, which may or may not be supported in Colab.
Q 3.17: Will Aerial Framework run better with PyTorch? Are there any tradeoffs?
A: Current Aerial Framework receiver is written in JAX. Support will be added for more PyTorch models in future releases.
Q 3.18: What is the framework used for Mac layer scheduler?
A: Aerial Framework currently only supports PHY layer reference modules.
Q 3.19: Can we have dev environment using CPU?
A: No, a recent GPU (Ampere+) is required for the Development environment.
Q 3.20: Can you highlight the differences in the 5G and 6G versions of Aerial and other frameworks?
A: The same Aerial components can be used for 5G today and extended to 6G in the future.
Q 3.21: What is specific to 6G Aerial and other tool chains versus their 5G NR versions?
Q 3.22: Is it possible to emulate 100 gNB as a small AI-Native RAN?
A: Aerial Framework does not currently support that many cells.
Q 3.23: How is Aerial Framework different from pyAerial?
A: pyAerial is for prototyping and simulating in Python but it is not real-time. Aerial Framework is for developing algorithms in Python and lowering them to run real-time.
Q 3.24: How would you recommend 'Side Processing’ for processing I/Q data outside of RAN pipeline, that is, is parallel?
A: DOCA GPU NetIO allows moving data directly from NIC to GPU and calling network APIs from the GPU, bypassing the CPU.
Q 3.25: Is the python library used a GPU base library?
A: Yes, the Python code is lowered to TensorRT/CUDA and executes natively on the GPU.
Q 3.26: How many UE can be onboarded into Aerial Framework?
A: The current reference supports one, but more will be added in the next release.
Q 3.27: Is the Aerial runtime able to provide a complete 5G network usable with UEs like Sionna RK?
A: A user can run Aerial CUDA Accelerated RAN with UEs as a part of Aerial Testbed.
Q 3.28: What is the difference between the Aerial CUDA Accelerated RAN and the Aerial Framework?
A: ACAR (Aerial CUDA-Accelerated RAN) is an L1/L2 O-DU stack. It has a 5G-compliant PHY/MAC implementation and a runtime. Aerial Framework enables you to run CUDA PHY pipelines and write your own using the toolchain to lower algorithms from high level languages like Python and run them real time. It also has a runtime but is currently geared to be modular and flexible.
Q 3.29: How can developers monetize their efforts? Doing open source means no monetizing of the code itself. Maybe the only way is if developing SEP.
A: Aerial Framework is licensed under Apache 2.0
Q 3.30: For a heavy PyTorch user, will there be any support for PyTorch in the future in terms of integration or anything?
A: Current receiver is written in JAX, and support will be added for more PyTorch models in future releases.
Q 3.31: Is there any framework for running the physical layer alone in real time mode?
A: Yes, this is supported.
Q 3.32: What hardware is needed to run Aerial Framework?
A: A40 (Ampere) is sufficient for Development. Runtime currently requires GH200.
Q 3.33: In the tutorial, how do you configure the pipeline in terms of number of receive/transmit antennas etc.?
A: The receiver currently only supports 4 antennas, and more antenna combinations will be added in future releases.
Q 3.34: Is Aerial Framework supported on macOS?
A: Aerial Framework is only supported on Linux.
Q 3.35: Can we deploy Aerial Framework on cloud?
A: Yes, if the cloud instance provides the required GPU (Ampere+) and OS (Ubuntu) for Development.
Q 3.36: Any tools to estimate power consumption levels of the Aerial Framework receiver?
A: This is being considered for the next release, but a user can start with NVML NVIDIA Management Library to measure GPU power consumption.
Q 3.37: What kind of desktop and video target is needed to take advantage of Aerial Framework?
Q 3.38: Is it possible to integrate between Aerial Framework with Sionna?
Q 3.39: Can Aerial Framework be used for UE development?
A: The current version of Aerial Framework is focusing on DU.
Q 3.40: Do you have performance figures for these 5G PUSCH Rx pipelines with ARC-Pro?
A: The runtime environment currently only supports GH200. However, it is possible to run benchmarks using the development environment with ARC-Pro.
Q 3.41: Can the Framework convert c code into CUDA code?
A: A user can directly write C/C++ CUDA kernels and run them in Framework.
Q 3.42: How does the Framework handle performance optimization when mixing Python and CUDA modules?
A: Python will be lowered to TensorRT engine(s). The performance of different modules (CUDA, TensorRT) will be based on each modules’ optimization. The runtime handles a mix of CUDA and TensorRT modules.
Q 3.43: What hardware is needed to install Aerial Framework?
Q 3.44: I want the hardware setup with DGX Spark B210 and modems? Could you be specific on that if I procure the entire end to end set up.
A: DGX Spark is supported for Aerial Framework, but B210 modems are not currently supported.
Q 3.45: What differs from the dev vs runtime environments apart from GH200 support only?
A: Runtime requires real-time kernel, isolated CPU cores, and specific NIC config (PTP).
