I am working on a Jetson Xavier and am trying to build the anomaly application listed here:
https://github.com/NVIDIA-AI-IOT/deepstream_reference_apps/tree/master/anomaly
I managed to build the deepstream-yolo app and run it fine; however, when I tried to build the dsoptical plugin for the anomaly app, I get this error:
[ 80%] Building CXX object CMakeFiles/gstdsopticalflow.dir/gstdsopticalflow.cpp.o
/home/nvidia/deepstream_reference_apps/anomaly/plugins/gst-dsopticalflow/gstdsopticalflow.cpp: In function ‘GstFlowReturn gst_ds_optical_flow_transform_internal(GstBaseTransform*, GstBuffer*, GstBuffer*)’:
/home/nvidia/deepstream_reference_apps/anomaly/plugins/gst-dsopticalflow/gstdsopticalflow.cpp:488:13: error: ‘CHECK_NVDS_MEMORY_AND_GPUID’ was not declared in this scope
if (CHECK_NVDS_MEMORY_AND_GPUID (dsopticalflow, surface))
/home/nvidia/deepstream_reference_apps/anomaly/plugins/gst-dsopticalflow/gstdsopticalflow.cpp:506:80: error: ‘NvBufSurface {aka struct _NvBufSurface}’ has no member named ‘buf_data’; did you mean ‘buf_fds’?
(DsOpticalFlowProcess(dsopticalflow->dsopticalflowlib_ctx, surface->buf_data[0],
buf_fds
CMakeFiles/gstdsopticalflow.dir/build.make:62: recipe for target 'CMakeFiles/gstdsopticalflow.dir/gstdsopticalflow.cpp.o' failed
make[2]: *** [CMakeFiles/gstdsopticalflow.dir/gstdsopticalflow.cpp.o] Error 1
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/gstdsopticalflow.dir/all' failed
make[1]: *** [CMakeFiles/gstdsopticalflow.dir/all] Error 2
Makefile:129: recipe for target 'all' failed
make: *** [all] Error 2
How would I go about fixing this so I can run the application? I have OpenCV 4.0.1 built with contrib as explained in the readme. Is there something wrong with my DeepStream installation? Right now, my DS_SDK_PATH is pointing to the top directory (that includes binaries, LicenseAgreement, README, samples, sources).
Thank you so much!
