If you are reporting a bug or error, consider submitting a Support Bundle to aiworkbench-ea@nvidia.com. This will help us solve your issue more quickly.
Please describe your issue or request: (tick the boxes after creating this topic):
Please tick the appropriate box to help us categorize your post
Bug or Error
Feature Request
Documentation Issue
Other
I am using a nvidia nim anywhere project in workbench configuring mounts for the project. I kept seeing an error when I launched jupyter notebook saying docker was not found at /var/host-run/ Well I knew I had changed that in the environment mounts so found it in the postbuild script and changed it.
When I closed the edit, the project went into rebuild mode and got stuck on step 6. I closed the project & workbench, but it was still building when I relaunched. I even restarted the computer. When I press the stop build button it says there is a problem stopping. So I went to the logs and it said it is trying to stop a container that isn’t running.
So do I have an option other than to remove the project and start over?
