Followed the link, Welcome — Jetson Linux<br/>Developer Guide 34.1 documentation
and modified the DTB as specified, able to overcome the dma address issue.
Hello everyone,
Can you tell exactly how you followed the instruction to modify DTB?
I followed the instruction however it mainly covers on how to compile the new kernel while as far as I understand this, the need is to alter the file within hardware folder and not the kernel itself (considering that kernel_src consists of the following two folders: hardware and kernel)
Would appreciate any direction on this matter.
Yes, i had to change in hardware folder. When i build the kernel, changes were effective and new kernel-4.9/kernel_build/arch/arm64/boot/dts/tegra210-p3448-0000-p3449-0000-b00.dtb was created.
Looks like nvidia has modified the kernel to build. So, give it a try with kernel build.
Thanks ganga. I did the part with building the kernel, now i got stuck how to flash it, can you advise how did you do it?
I have complied the kernel on the actual nano…
I have used external Host to build an image, after the kernel build, i copied Image and dtb into Linux_for_Tegra and used a script file to create the sd-card image.
Commands used:
$TEGRA_KERNEL_OUT/arch/arm64/boot/Image – <release_packagep>/Linux_for_Tegra/kernel/Image
cp ./arch/arm64/boot/Image …/…/…/…/Linux_for_Tegra/kernel/Image
$TEGRA_KERNEL_OUT/arch/arm64/boot/dts/ – Linux_for_Tegra/kernel/dtb/
cp -R ./arch/arm64/boot/dts/ …/…/…/…/Linux_for_Tegra/kernel/dtb/
sudo ./apply_binaries.sh
And then created a sd-card image with script,
sudo ./create-jetson-nano-sd-card-image.sh -o sd-blob-b01.img -s 10G -r 300
Thanks ganga. Managed to get it done and also overcome the problem with Wifi.
Few remarks though:
Basically followed the following when it comes to building the kernel:
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3231/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fkernel_custom.html%23
and this one in order to flash my image:
Although had to overcome few obstacles along the road: in the NVIDIA guide name of script is different, also had to download few files in addition like L4T Driver package and Sample root file system.
Nevertheless, achieved what i needed after few hours.
Cheers.
I finally got around to trying the fix today! it worked like a charm. I have to say that figuring out how to build and flash the DTB and kernel was a pain though… the instructions are not very well written in my opinion. Anyway, for reference here is a step by step:
Required:
Computer with Ubuntu and Jetpack SDK installer, with the Jetson Nano jetpack downloaded
Steps:
On the computer go to the folder where Jetpack is installed
cd ~/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO/Linux_for_Tegra
Find the tag for the kernel sources you need. For Jetpack 4.3 it was tegra-l4t-r32.3.1
Use source_sync.sh
script to download the kernel sources, you will be asked for the above tag to download the correct version of the sources
$ ./source_sync.sh
After the above finishes, the source files will be at:
~/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO/Linux_for_Tegra/sources
Find the file mentioned in th post above:
Continue building the kernel, set the output folder where you want the new files to be built:
$ TEGRA_KERNEL_OUT=~/KernelBuild
Find the path to. the arm64 toolchain
$ which aarch64-linux-gnu-cpp
the output should be something like: /usr/bin/aarch64-linux-gnu-cpp
Set the variables for cross-compiling, use the output from the above command with. out the cpp
part:
$ export CROSS_COMPILE=/usr/bin/aarch64-linux-gnu-
$ export LOCALVERSION=-tegra
Create the .config
file by executing the following commands:
$ cd ~/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO/Linux_for_Tegra/sources/kernel/kernel-4.9
$ mkdir -p $TEGRA_KERNEL_OUT
$ make ARCH=arm64 O=$TEGRA_KERNEL_OUT tegra_defconfig
Build the Kernel and all DTBs (note <n>
is the number of processors available -1):
$ make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j<n>
Copy the created image and DTBs to the JetPack folder:
$ cp $TEGRA_KERNEL_OUT/arch/arm64/boot/Image ~/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO/Linux_for_Tegra/kernel/Image
$ cp -r $TEGRA_KERNEL_OUT/arch/arm64/boot/dts/* ~/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO/Linux_for_Tegra/kernel/dtb/
Install the Kernel Modules:
$ sudo make ARCH=arm64 O=$TEGRA_KERNEL_OUT modules_install INSTALL_MOD_PATH=~/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO/Linux_for_Tegra/rootfs/
create an archive of. the kernel modules and replace the old ones (replace <yourusername>
with your linux user to set the correct owner of the file) :
$ cd <modules_install_path>
$ sudo tar --owner root --group root -cjf kernel_supplements.tbz2 lib/modules
$ mv ~/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO/Linux_for_Tegra/kernel/kernel_supplements.tbz2 ~/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO/Linux_for_Tegra/kernel/kernel_supplements.tbz2.orig
$ sudo mv kernel_supplements.tbz2 ~/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO/Linux_for_Tegra/kernel/
$ sudo chown <yourusername>:<yourusername> ~/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO/Linux_for_Tegra/kernel/kernel_supplements.tbz2
Apply the binaries you just created:
$ sudo ./apply_binaries.sh
At this point you either need to create an SD Card image for the Nano, or in my case I had to flash a production module with the updated kernel using the following command.
$ sudo ./flash.sh -r jetson-nano-emmc mmcblk0p1
After this is done follow the normal initial configuration steps on the Nano and you image will no longer have the issue.
Hope this makes it easier for anyone to modify and rebuild the kernel if needed.
Hi, @Manikanta, could you help with similar issue with QCNFA335?
[ 6.031485] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.060275] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.161363] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.182632] mc-err: (0) csw_afiw: EMEM address decode error
[ 6.188332] mc-err: status = 0x20011031; addr = 0x65e17060
[ 6.194056] mc-err: secure: no, access-type: write, SMMU fault: none
[ 6.204215] mc-err: (0) csw_afiw: EMEM address decode error
[ 6.209878] mc-err: status = 0x20011031; addr = 0x65e18060
[ 6.215612] mc-err: secure: no, access-type: write, SMMU fault: none
[ 6.237889] mc-err: (0) csw_afiw: EMEM address decode error
[ 6.243527] mc-err: status = 0x20011031; addr = 0x65e19060
[ 6.249255] mc-err: secure: no, access-type: write, SMMU fault: none
[ 6.273950] mc-err: (0) csr_afir: EMEM address decode error
[ 6.279582] mc-err: status = 0x2000000e; addr = 0x5d9ffe00
[ 6.285328] mc-err: secure: no, access-type: read, SMMU fault: none
[ 6.303306] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.303359] Bluetooth: BNEP socket layer initialized
[ 6.312131] mc-err: Too many MC errors; throttling prints
I tried your solution here and recompile the kernel but it didn’t work.
This seem also has been reported here
Additional info: the first time the image booted and I had to setup the wifi connection in the wizard, it worked. But after it reboots, that error above is shown in dmesg.
Can you execute below script and provide output?
#!/bin/bash
shopt -s nullglob
for g in /sys/kernel/iommu_groups/; do
echo "IOMMU Group ${g##/}:"
for d in $g/devices/; do
echo -e "\t$(lspci -nns ${d##/})"
done;
done;
Thanks,
Manikanta
Thanks for your attention to this, Manikananta,
I found that the device list formats are not ready for lspci -nns, so I modified the scrip to list them as is (without feeding to lspci -nns):
IOMMU Group 0
tegra-carveouts
IOMMU Group 1
smmu_test
IOMMU Group 2
70090000.xusb
IOMMU Group 3
70006000.serial
IOMMU Group 4
70006040.serial
IOMMU Group 5
70006200.serial
IOMMU Group 6
sound
IOMMU Group 7
7000d400.spi
IOMMU Group 8
7000d600.spi
IOMMU Group 9
70410000.spi
IOMMU Group 10
50000000.host1x
IOMMU Group 11
54080000.vi
IOMMU Group 12
54600000.isp
IOMMU Group 13
54680000.isp
IOMMU Group 14
tegradc.0
IOMMU Group 15
tegradc.1
IOMMU Group 16
54340000.vic
IOMMU Group 17
544c0000.nvenc
IOMMU Group 18
54500000.tsec
IOMMU Group 19
54100000.tsecb
IOMMU Group 20
54480000.nvdec
IOMMU Group 21
54380000.nvjpg
IOMMU Group 22
546c0000.i2c
IOMMU Group 23
57000000.gpu
IOMMU Group 24
70012000.se
IOMMU Group 25
7000c000.i2c
IOMMU Group 26
7000c400.i2c
IOMMU Group 27
7000c500.i2c
IOMMU Group 28
7000c700.i2c
IOMMU Group 29
7000d000.i2c
IOMMU Group 30
7000d100.i2c
IOMMU Group 31
sdhci-tegra.0
IOMMU Group 32
700d0000.xudc
IOMMU Group 33
702ef000.adsp
IOMMU Group 34
aconnect@702c0000:adsp_audio
IOMMU Group 35
serial8250
IOMMU Group 36
snd-soc-dummy
Here’s an output of lspci -nn
00:01.0 PCI bridge [0604]: NVIDIA Corporation Device [10de:0fae] (rev a1)
00:02.0 PCI bridge [0604]: NVIDIA Corporation Device [10de:0faf] (rev a1)
01:00.0 Network controller [0280]: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter [168c:0036] (rev 01)
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
and -vv:
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 84
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: 13000000-130fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
Capabilities: [48] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
Mapping Address Base: 00000000fee00000
Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag+ RBE+
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
LnkCtl: ASPM L0s L1 Enabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd On, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet+ LinkState+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=30us PortTPowerOnTime=70us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=30us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=70us
Kernel driver in use: pcieport
00:02.0 PCI bridge: NVIDIA Corporation Device 0faf (rev a1) (prog-if 00 [Normal decode])
Latency: 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: 13100000-131fffff
ExtTag+ RBE+
LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
T_CommonMode=150us LTR1.2_Threshold=294912ns
L1SubCtl2: T_PwrOn=150us
01:00.0 Network controller: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter (rev 01)
Subsystem: Lite-On Communications Inc QCA9565 / AR9565 Wireless Network Adapter
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0, Cache Line Size: 64 bytes
Region 0: Memory at 13000000 (64-bit, non-prefetchable) [size=512K]
[virtual] Expansion ROM at 13080000 [disabled] [size=64K]
Capabilities: [40] Power Management version 2
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Capabilities: [50] MSI: Enable- Count=1/4 Maskable+ 64bit+
Masking: 00000000 Pending: 00000000
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
DevSta: CorrErr- UncorrErr+ FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
UESta: DLP- SDES- TLP- FCP- CmpltTO+ CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
AERCap: First Error Pointer: 0e, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [140 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Capabilities: [160 v1] Device Serial Number 00-00-00-00-00-00-00-00
Kernel driver in use: ath9k
Kernel modules: ath9k
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 406
Region 0: I/O ports at 1000 [size=256]
Region 2: Memory at 13104000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at 13100000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fa81f000 Data: 0000
Capabilities: [70] Express (v2) Endpoint, MSI 01
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
MaxPayload 128 bytes, MaxReadReq 4096 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 <64us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Via message/WAKE#
Capabilities: [b0] MSI-X: Enable- Count=4 Masked-
Vector table: BAR=4 offset=00000000
PBA: BAR=4 offset=00000800
Capabilities: [100 v2] Advanced Error Reporting
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq+ ACSViol-
Status: InProgress-
Capabilities: [170 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [178 v1] L1 PM Substates
PortCommonModeRestoreTime=150us PortTPowerOnTime=150us
T_CommonMode=0us LTR1.2_Threshold=294912ns
Kernel driver in use: r8168
I don’t find AFI as part of iommu group, so the change is not applied correctly. Please follow the steps shared by Jaime and verify.
Thanks,
Manikanta
OK, seems like I needed to do “make clean” before recompiling the kernel.
It’s working, now. Many thanks!
