The spreadsheet calculator… I think it was called “occupancy calculator” or something like that… what is it’s algorithm ? Does it use a solver ?
I would definetly be interested in it’s algorithm… perhaps then I and others could code it into their applications for automatic calculations of optimal kernel execution configurations…
Therez no specific algorithm. It is a collection of facts about NVIDIA hardware. You can examine the logic of the spreadsheet if its not hidden or protected. That should give you the clue…
I think there are some XL to C++ converters available. Check out.
The Occupancy calculator does not solve for the optimal number of threads per block. As Sarnath stated, it’s just a collection of facts about hardware of different CUDA capabilities that you can also find in the Programming Guide, and calculates the occupancy for each of them. Check it out yourself, the formulas in it are not hidden or protected in any way.
As occupancy is not directly related to performance, there would also be no point in optimizing for it. The usual use case is to use the Occupancy calculator to roughly see where you stand, and then try a few sensible configurations (i.e., multiples of 32 threads) to find the one that is performing best.
