Hi everyone,
I met a problem after I installed the CUDA 10.4 on my Ubuntu 18.04 server. I found all the files under the CUDA folder are disappear! Can you help me with this issue? Thank you a lot in advance!
Here are some details of my questions.
Firstly, I followed the steps below to uninstall the existing CUDA, and installed the latest version:
Uninstall
sudo apt-get purge nvidia*
sudo apt-get autoremove
sudo apt-get autoclean
sudo rm -rf /usr/local/cuda*
Install
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt updat
sudo ubuntu-drivers autoinstall
sudo apt install nvidia-cuda-toolkit
Everything looks good at this moment, here are some install results:
$ nvidia-smi
Mon May 25 02:32:42 2020
| NVIDIA-SMI 440.82 Driver Version: 440.82 CUDA Version: 10.2 |
| 0 Quadro K600 Off | 00000000:02:00.0 On | N/A |
| 31% 62C P0 N/A / N/A | 422MiB / 974MiB | 1% Default |
| 1 GeForce GTX 106... Off | 00000000:03:00.0 Off | N/A |
| 0% 40C P8 4W / 120W | 15MiB / 6078MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1432 G /usr/lib/xorg/Xorg 31MiB |
| 0 1500 G /usr/bin/gnome-shell 51MiB |
| 0 1681 G /usr/lib/xorg/Xorg 95MiB |
| 0 1799 G /usr/bin/gnome-shell 89MiB |
| 0 2687 G ...AAAAAAAAAAAAAAgAAAAAAAAA --shared-files 148MiB |
| 1 1432 G /usr/lib/xorg/Xorg 5MiB |
| 1 1681 G /usr/lib/xorg/Xorg 6MiB |
$ nvcc --version
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Fri_Nov__3_21:07:56_CDT_2017
Cuda compilation tools, release 9.1, V9.1.85
Then the question came. Normally CUDA should under /usr/local, but I cannot find it there. Hence I tried:
locate cuda | grep /cuda$
/home/zihan/.local/lib/python3.6/site-packages/torch/cuda
/home/zihan/.local/lib/python3.6/site-packages/torch/backends/cuda
/home/zihan/.local/lib/python3.6/site-packages/torch/include/ATen/cuda
/home/zihan/.local/lib/python3.6/site-packages/torch/include/c10/cuda
/home/zihan/.local/lib/python3.6/site-packages/torch/include/torch/csrc/cuda
/home/zihan/anaconda3/lib/python3.7/site-packages/numba/cuda
/home/zihan/anaconda3/lib/python3.7/site-packages/tensorflow_core/include/external/local_config_cuda/cuda
/home/zihan/anaconda3/lib/python3.7/site-packages/tensorflow_core/include/external/local_config_cuda/cuda/cuda
/home/zihan/anaconda3/lib/python3.7/site-packages/tensorflow_core/include/tensorflow/stream_executor/cuda
/home/zihan/anaconda3/lib/python3.7/site-packages/torch/cuda
/home/zihan/anaconda3/lib/python3.7/site-packages/torch/backends/cuda
/home/zihan/anaconda3/lib/python3.7/site-packages/torch/include/ATen/cuda
/home/zihan/anaconda3/lib/python3.7/site-packages/torch/include/c10/cuda
/home/zihan/anaconda3/lib/python3.7/site-packages/torch/include/torch/csrc/cuda
/home/zihan/anaconda3/pkgs/numba-0.45.1-py37h962f231_0/lib/python3.7/site-packages/numba/cuda
/home/zihan/anaconda3/pkgs/pytorch-1.3.1-cuda100py37h53c1284_0/lib/python3.7/site-packages/torch/cuda
/home/zihan/anaconda3/pkgs/pytorch-1.3.1-cuda100py37h53c1284_0/lib/python3.7/site-packages/torch/backends/cuda
/home/zihan/anaconda3/pkgs/pytorch-1.3.1-cuda100py37h53c1284_0/lib/python3.7/site-packages/torch/include/ATen/cuda
/home/zihan/anaconda3/pkgs/pytorch-1.3.1-cuda100py37h53c1284_0/lib/python3.7/site-packages/torch/include/c10/cuda
/home/zihan/anaconda3/pkgs/pytorch-1.3.1-cuda100py37h53c1284_0/lib/python3.7/site-packages/torch/include/torch/csrc/cuda
/home/zihan/anaconda3/pkgs/tensorflow-base-1.15.0-gpu_py37h9dcbed7_0/lib/python3.7/site-packages/tensorflow_core/include/external/local_config_cuda/cuda
/home/zihan/anaconda3/pkgs/tensorflow-base-1.15.0-gpu_py37h9dcbed7_0/lib/python3.7/site-packages/tensorflow_core/include/external/local_config_cuda/cuda/cuda
/home/zihan/anaconda3/pkgs/tensorflow-base-1.15.0-gpu_py37h9dcbed7_0/lib/python3.7/site-packages/tensorflow_core/include/tensorflow/stream_executor/cuda
/home/zihan/anaconda3/pkgs/tensorflow-base-1.15.0-mkl_py37he1670d9_0/lib/python3.7/site-packages/tensorflow_core/include/external/local_config_cuda/cuda
/home/zihan/anaconda3/pkgs/tensorflow-base-1.15.0-mkl_py37he1670d9_0/lib/python3.7/site-packages/tensorflow_core/include/external/local_config_cuda/cuda/cuda
/home/zihan/anaconda3/pkgs/tensorflow-base-1.15.0-mkl_py37he1670d9_0/lib/python3.7/site-packages/tensorflow_core/include/tensorflow/stream_executor/cuda
/usr/include/thrust/system/cuda
/usr/lib/cuda
Then I went to /usr/lib/cuda to check it. However, I found all folders inside CUDA are empty. I mean, everything disappears!
/usr/lib/cuda$ ls
bin include lib64 nvvm version.txt
/usr/lib/cuda/bin$ ls -l
total 0
# (questions are same in other folders, like lib64)
/usr/lib/cuda/lib64$ ls -l
total 0
May I ask where these files go? Why this happens, and how can I fix that? Thank you a lot for your help in advance.
