All Linux distros fail to boot on Geforce 960M
Hello everyone!
I have a Laptop with Geforce 960m + Intel 6700 HQ, but unfortunately I haven’t been able to boot Linux on this machine after some recent driver updates (470, 535, 550 series, to name a few).
I’ve so far tried Ubuntu 22.0.4, 24.0.4, Manjaro 24.0.5 and Fedora 40. All to no avail.
Is there anything I can do track this down?
I’ve already filed a bug at Bug #2071680 “Ubuntu fails to boot” : Bugs : Ubuntu.
But unfortunately journalctl fails to capture the failed boot logs (it only logs if only you boot via recovery mode).
So how can I track this issue, to see if it’s either fixed on future driver updates, or report it as a bug?
More system info:
https://0x0.st/XV0M.txt
close the Intel HD Graphics 530 in bios,then re-try
Hi, @990178851 , unfortunately it doesn’t have such options, even though I have the latest BIOS:
BIOS options
what in this
@990178851, This is how the Graphics Configuration settings looks:
So there is no option for disabling or enabling, but only for DVMT Pre-Allocation.
Furthermore, if I switch away from intel vi prime-select nvidia from terminal, I get a blackscreen even when booting via recovery mode. So not sure if disabling intel could work as a workaround.
1、Maybe you can install the nvidia 560 driver without the nvidia card plugging in fresh fedora40 installed,
2、then power off,and plug nvidia card,
3、reboot to see
use method 2
@990178851
  1. Unfortunately my system is a laptop, therefore I can’t physically unplug the card.
  2. As for 560, I’ve already tried it on Ubuntu 24.10, and it didn’t work.
