Hi! I already follow the step doing re-training dataset but my all training images got acc@5 100.000 and got 100.00% when running the live camera program using web camera. Is it normal or one of the error in re-training images?
It is possible for small training data or simple use cases.
If you can also get high accuracy with real input data, it should be okay.
acc@5 means top-5 accuracy (i.e. if the correct class is in any of the model’s top 5 highest-confidence predictions). If your dataset has 5 or less classes, than it will always be 100%.
