Hi @ShaneCCC,
Thanks for your reply.
I talked with them but they said the same. To use they cameras now python 3.7 is a minimum requirement.
I tried to upgrade Python 3.6.9 to 3.7, but after running this command:
sudo update-alternatives --config python3
the terminal and software updates stop working…
Reading other post, related to upgrade it and why is needed has been discussed before and still open.
Not sure if you guys (NVIDIA) can suggest what to do, because clearly Allied Vision can not.
