I use VimbaPython as API for Allied Vision camera, which is connected through USB port to Nvidia Jetson Orin NX.
Is possible to stream frames from camera directly to GPU memory? Now I need to capture frames on CPU and then send it to GPU through object like in following example:
Transfer image to GPU
gpu_frame = cv.cuda_GpuMat()
gpu_frame.upload(img_cpu)
Now I need copy each frame in this way, but it is time consumption.
Is any better way to transfer frames from AlliedVision camera directly do GPU memory, taken into account, that camera is connected through USB 3.0 interface?
Thank You very much for help and any suggestions.
Best regards
Jakub Slon
