It seems that there is a bug in libnvfnet–if you compile the 00_video_decode sample with AddressSanitizer (add CC=clang CPP=clang++ CFLAGS+=-fsanitize=address CPPFLAGS+=-fsanitize=address to Rules.mk) you get the following error:
./video_decode H264 ~/sky.h264
Set governor to performance before enabling profiler
Creating decoder in blocking mode
==8942==ERROR: AddressSanitizer: alloc-dealloc-mismatch (malloc vs operator delete) on 0xffffb5a03450
#0 0x4bee24 in operator delete(void*, unsigned long) (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x4bee24)
#1 0xffffba3c3ab4 in __cxa_finalize /build/glibc-RIFKjK/glibc-2.31/stdlib/cxa_finalize.c:83:6
#2 0xffffb4d5c68c (/usr/lib/aarch64-linux-gnu/tegra/libnvfnet.so+0x768c)
#3 0xffffbd96ef14 in call_destructors /build/glibc-RIFKjK/glibc-2.31/elf/dl-close.c:125:3
#4 0xffffba497078 in _dl_catch_exception /build/glibc-RIFKjK/glibc-2.31/elf/dl-error-skeleton.c:182:7
#5 0xffffbd96f4fc in _dl_close_worker /build/glibc-RIFKjK/glibc-2.31/elf/dl-close.c:297:3
#6 0xffffbd96f4fc in _dl_close_worker /build/glibc-RIFKjK/glibc-2.31/elf/dl-close.c:135:1
#7 0xffffbd97001c in _dl_close /build/glibc-RIFKjK/glibc-2.31/elf/dl-close.c:859:3
#8 0xffffba497018 in _dl_catch_exception /build/glibc-RIFKjK/glibc-2.31/elf/dl-error-skeleton.c:208:8
#9 0xffffba4970e4 in _dl_catch_error /build/glibc-RIFKjK/glibc-2.31/elf/dl-error-skeleton.c:227:19
#10 0xffffba525834 in _dlerror_run /build/glibc-RIFKjK/glibc-2.31/dlfcn/dlerror.c:170:21
#11 0xffffba5251cc in dlclose /build/glibc-RIFKjK/glibc-2.31/dlfcn/dlclose.c:46:10
#12 0x46d6e8 in dlclose (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x46d6e8)
#13 0xffffbd7f7a10 (/lib/aarch64-linux-gnu/libv4l2.so.0+0x8a10)
#14 0xffffbd7f226c in v4l2_fd_open (/lib/aarch64-linux-gnu/libv4l2.so.0+0x326c)
#15 0xffffbd7f299c in v4l2_open (/lib/aarch64-linux-gnu/libv4l2.so.0+0x399c)
#16 0x581cc4 in NvV4l2Element::NvV4l2Element(char const*, char const*, int, int) (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x581cc4)
#17 0x4defc4 in NvVideoDecoder::NvVideoDecoder(char const*, int) (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x4defc4)
#18 0x4df03c in NvVideoDecoder::createVideoDecoder(char const*, int) (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x4df03c)
#19 0x4c3eb0 in decode_proc(context_t&, int, char**) (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x4c3eb0)
#20 0x4c39fc in main (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x4c39fc)
#21 0xffffba3ade0c in __libc_start_main /build/glibc-RIFKjK/glibc-2.31/csu/../csu/libc-start.c:308:16
#22 0x4258a0 in _start (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x4258a0)
0xffffb5a03450 is located 0 bytes inside of 40-byte region [0xffffb5a03450,0xffffb5a03478)
allocated by thread T0 (DecOutPlane) here:
#0 0x492744 in malloc (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x492744)
#1 0xffffb4d5cd48 in fnet::String::String(char const*) (/usr/lib/aarch64-linux-gnu/tegra/libnvfnet.so+0x7d48)
#2 0xffffbd96a9b0 in call_init /build/glibc-RIFKjK/glibc-2.31/elf/dl-init.c:30:6
#3 0xffffbd96a9b0 in _dl_init /build/glibc-RIFKjK/glibc-2.31/elf/dl-init.c:119:5
#5 0xffffbd96ea10 in dl_open_worker /build/glibc-RIFKjK/glibc-2.31/elf/dl-open.c:758:5
#6 0xffffba497018 in _dl_catch_exception /build/glibc-RIFKjK/glibc-2.31/elf/dl-error-skeleton.c:208:8
#7 0xffffbd96e1a0 in _dl_open /build/glibc-RIFKjK/glibc-2.31/elf/dl-open.c:837:17
#8 0xffffba525098 in dlopen_doit /build/glibc-RIFKjK/glibc-2.31/dlfcn/dlopen.c:66:15
#9 0xffffba497018 in _dl_catch_exception /build/glibc-RIFKjK/glibc-2.31/elf/dl-error-skeleton.c:208:8
#10 0xffffba4970e4 in _dl_catch_error /build/glibc-RIFKjK/glibc-2.31/elf/dl-error-skeleton.c:227:19
#11 0xffffba525834 in _dlerror_run /build/glibc-RIFKjK/glibc-2.31/dlfcn/dlerror.c:170:21
#12 0xffffba52513c in dlopen /build/glibc-RIFKjK/glibc-2.31/dlfcn/dlopen.c:87:10
#13 0x46d668 in dlopen (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x46d668)
#14 0xffffbd7f7a58 (/lib/aarch64-linux-gnu/libv4l2.so.0+0x8a58)
#15 0x4defc4 in NvVideoDecoder::NvVideoDecoder(char const*, int) (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x4defc4)
#16 0x4df03c in NvVideoDecoder::createVideoDecoder(char const*, int) (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x4df03c)
#17 0x4c3eb0 in decode_proc(context_t&, int, char**) (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x4c3eb0)
#18 0x4c39fc in main (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x4c39fc)
#19 0xffffba3ade0c in __libc_start_main /build/glibc-RIFKjK/glibc-2.31/csu/../csu/libc-start.c:308:16
#20 0x4258a0 in _start (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x4258a0)
SUMMARY: AddressSanitizer: alloc-dealloc-mismatch (/home/russell/jetson_multimedia_api/samples/00_video_decode/video_decode+0x4bee24) in operator delete(void*, unsigned long)
==8942==HINT: if you don't care about these errors you may set ASAN_OPTIONS=alloc_dealloc_mismatch=0
==8942==ABORTING
The hack suggested in Memory Leak (Alloc/free mismatch) in Tegra multimedia API (encoder) - #6 by DaneLLL does indeed work, but considering that was over a year ago and this is a later release, clearly the bug was not fixed. I do not think renaming that file is an acceptable fix.
System info: Jetpack 5.0.2 with BSP 35.1 AGX Xavier
