Tried your code and be able to run without error.(I replace ocvAcqFrame with cv::Mat)
Could you check if there is something wrong in ocvAcqFrame allocation?
#include <iostream>
#include <opencv2/core/core.hpp>
#include "opencv2/gpu/gpu.hpp"
int main()
cv::Mat buf(480,620,CV_8UC3);
cv::Mat res(480,640,CV_8UC3);
cv::gpu::CudaMem gpu_frame_mem( buf, cv::gpu::CudaMem::ALLOC_ZEROCOPY );
cv::gpu::CudaMem gpu_res_mem( res, cv::gpu::CudaMem::ALLOC_ZEROCOPY );
cv::gpu::GpuMat gpu_frame = gpu_frame_mem.createGpuMatHeader();
cv::gpu::GpuMat gpu_res = gpu_res_mem.createGpuMatHeader();
cv::gpu::resize( gpu_frame, gpu_res, cv::Size(640,480) );
// gpu_res.download( res ); <--- This works
res = gpu_res_mem.createMatHeader();
std::cout << "All goods" << std::endl;
return 0;
I’m writing a benchmark application to better understand this issue and I’m facing really strange behaviours.
For example:
resize in a pipeline where GpuMat is initialized with “upload” takes about 2 msec
resize in a pipeline where GpuMat is initialized with “ZEROCOPY” takes about 32 msec
The benchmark is available on Github:
I replied to the topic you suggested to me with the result of one of my test…
Thanks for your feedback.
May I know which your target device is since you mentioned that you will try tx1 and tx2.
We can check the performance issue together after clarifying the target device.
