Allocating array pointers segfaults What am I doing wrong?
I have the below code.
I tried in “normal” C first, and then I’m trying to transfer it to CUDA.
When I is 1, the program segfaults. I don’t understand why.
Perhaps I could gain more information from cuda-gdb, but I’m not sure how.
[codebox]int main() {
int **ptrArray;
//ptrArray = (int**)malloc(3 * sizeof(int*));
cudaError_t error = cudaMalloc( (void**) ptrArray, 3 * sizeof(int*));
for(int i = 0; i < 3; i++) {
  //ptrArray[i] = (int*)malloc(10 * sizeof(int));
  error = cudaMalloc( (void**) ptrArray[i], 10 * sizeof(int));
TehKernel<<<1, 1>>>(ptrArray);
}[/codebox]
Cuda-dgb:
[codebox][Thread debugging using libthread_db enabled]
[New process 30521]
[New Thread -1211263280 (LWP 30521)]
[New Thread -1215595632 (LWP 30524)]
[New Thread -1215861872 (LWP 30525)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1211263280 (LWP 30521)]
0xb7f76773 in cudaMalloc () from /opt/cuda/lib/libcudart.so.2[/codebox]
Hi!
ptrArray points to device code. This means that the value of ptrArray must be interpreted as an adress in device mem. But
is executed in host code. So dereferencing in ptrArray[i] is done on the CPU. And the value of the memory in host at adress (ptrArray + i) is something undefined.
[quote name=‘navier-stokes’ post=‘531319’ date=‘Apr 17 2009, 01:44 PM’]
Hi!
[codebox] int **ptrArray;
printf("%d\n", error);
int *ptrA, *ptrB, *ptrC;
error = cudaMalloc( (void**) ptrA, 10 * sizeof(int));
error = cudaMalloc( (void**) ptrB, 10 * sizeof(int));
error = cudaMalloc( (void**) ptrC, 10 * sizeof(int));
int *ptrS[3];
ptrS[0] = ptrA;
ptrS[1] = ptrB;
ptrS[2] = ptrC;
cudaMemcpy(ptrArray, ptrS, 3 * sizeof(int*), cudaMemcpyHostToDevice);[/codebox]
Thinking then, that if I allocate 4 arrays, and the copy the adresses to three of them to the last, I could achieve what I wanted (Which is sending over several arrays without getting a huge parameter list)
However, I still seg fault on the second Malloc.
Something else I can’t quite figure out is, why gdb claims there is no variable ptrA in current context.
Nevermind, my mallocs where wrong >_<
[codebox]global static void TehKernel(int **DArr) {
  printf("%p\n", DArr[i]);
template
T* SimpleCudaMalloc(const size_t size) {
T* devicePtr = NULL;
cudaError_t error = cudaMalloc((void**)&devicePtr, size * sizeof(T));
if (error == cudaErrorMemoryAllocation) {
  //cout << "CudaMalloc error: " << error << " (" << cudaGetErrorString(error) << ")" << ". Exiting" << endl;
  assert(false);
return devicePtr;
int main() {
const int popSize = 1024;
int *T, *V, *A;
T = SimpleCudaMalloc(popSize);
V = SimpleCudaMalloc(popSize);
A = SimpleCudaMalloc(popSize);
int **DArr, **HArr;
DArr = SimpleCudaMalloc<int*>(3);
HArr = (int**)malloc(3 * sizeof(int*));
HArr[0] = T;
HArr[1] = V;
HArr[2] = A;
  printf("%p\n", HArr[i]);
cudaMemcpy(HArr, DArr, 3 * sizeof(int*), cudaMemcpyHostToDevice);
TehKernel<<<1, 1>>>(DArr);
printf("\n");
}[/codebox]
The output when printing from the Kernel is just (nil).
And I got that figured out too ^^
Again my copying was wrong. Gonna stick to my templates next time ;)
Must be:
int **ptrArray;
   cudaError_t error = cudaMalloc( (void**)&ptrArray, 3 * sizeof(int*));
Hi Letharion,
Would you mind sharing your working code? I am also trying to make 2D arrays using memcpy2D but my code is not working. It’s very frustrating.
Dinh
EDIT: Got it to work…Why didn’t you use memcpy2D like this???
cudaMemcpy2D(DArr, popSize*sizeof(int), HArr, popSize*sizeof(int), popSize*sizeof(int), 3, cudaMemcpyHostToDevice);
