Dear PGI, i have some problems with the following code, the result is
Segmentation fault: 11
When c_process array is declared outside the simulation type it works.
threads and thread_id are set to one but in the real code it is controlled by openmp.
Other problem, i can’t toggle on the notification when somebody answers
to my post. The message is
“Sorry, but this e-mail address is invalid.
The current password you supplied does not match that stored in the database.”
But there is no place to fill in email or password.
module m_process
implicit none
type, abstract :: c_process
real :: t
contains
procedure(process_execution), pass(self), deferred :: run
end type c_process
abstract interface
subroutine process_execution(self, dt)
import c_process
class(c_process) :: self
real, intent(in) :: dt
end subroutine process_execution
end interface
type, extends(c_process) :: t_process
contains
procedure :: init => init_process
procedure :: run => run_process
end type t_process
contains
subroutine init_process(self)
class(t_process) :: self
self%t = 0.0
end subroutine init_process
subroutine run_process(self, dt)
self%t = self%t + dt
end subroutine run_process
end module m_process
module m_simulation
use m_process
implicit none
type :: t_simulation
class(c_process), pointer :: process(:)
integer :: np
contains
procedure :: init => init_simulation
procedure :: run => run_simulation
end type t_simulation
contains
subroutine init_simulation(self, np)
class(t_simulation) :: self
integer, intent(in) :: np
self%np = np
allocate( t_process :: self%process(np))
end subroutine init_simulation
subroutine run_simulation(self, n)
integer :: i, ip
real :: dt = 0.2
do ip = 1, self%np
do i = 1, n
call self%process(ip)%run(dt)
end do
end do
print*, self%process%t
end subroutine run_simulation
end module m_simulation
program test
use m_process
use m_simulation
implicit none
type(t_simulation) :: sim
integer :: nthreads, thread_id
nthreads = 1
thread_id = 1
call sim%init(nthreads)
select type ( p => sim%process(thread_id) )
type is ( t_process )
call p%init()
end select
call sim%run(5)
end program test
