Allocation vector larger than the GPU memory in Klepper / Maxewell
I have a machine with 12 gb of ram and I intend to buy one GTX750TI 2GB, using cuda 6 (which supports shared memory) can I create a vector of a 4 gigas and renders it this GPU?
You can’t create a 4GB “vector” in device memory on a system that has a 2GB GPU. You can use global memory that has been allocated on the host but is accessible to the GPU code (e.g. zero-copy) to allocate a 4GB device-accessible “vector” under some assumptions (e.g. UVA enabled system). Depending on your access patterns from device code, this could be horribly slow, or nearly as fast as if you had a (e.g.) 6GB GPU.
GPU memory limitations can also be worked around by dividing your problem into pieces, which can be successively transferred to the GPU and processed sequentially. This can have the added benefit of overlap of copy and compute to improve overall performance.
AFAIK CUDA 6 Unified Memory today does not address this limitation. Unified Memory can elect to use zero-copy allocations instead of ordinary device allocations, but I’m not sure this is user-controllable if only a single GPU is in the system. Even if it were, the net effect would still be the same as if you simply did a regular zero-copy allocation:
http://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#um-advanced-topics-hd
My plan is to use the cudamallocmanaged to allocate the vector with 4 gb, it is possible to access this vector from the gpu?
Yes but it’s slow. Instead, use asynchronous buffer streams.
Here’s a good example :
// Copyright 2012 NVIDIA Corporation
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
//     http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
#include <stdio.h>
// Convenience function for checking CUDA runtime API results
// can be wrapped around any runtime API call. No-op in release builds.
inline
cudaError_t checkCuda(cudaError_t result)
#if defined(DEBUG) || defined(_DEBUG)
  if (result != cudaSuccess) {
    fprintf(stderr, "CUDA Runtime Error: %s\n", cudaGetErrorString(result));
    assert(result == cudaSuccess);
#endif
  return result;
__global__ void kernel(float *a, int offset)
  int i = offset + threadIdx.x + blockIdx.x*blockDim.x;
  float x = (float)i;
  float s = sinf(x);
  float c = cosf(x);
  a[i] = a[i] + sqrtf(s*s+c*c);
float maxError(float *a, int n)
  float maxE = 0;
  for (int i = 0; i < n; i++) {
    float error = fabs(a[i]-1.0f);
    if (error > maxE) maxE = error;
  return maxE;
int main(int argc, char **argv)
  const int blockSize = 256, nStreams = 4;
  const int n = 4 * 1024 * blockSize * nStreams;
  const int streamSize = n / nStreams;
  const int streamBytes = streamSize * sizeof(float);
  const int bytes = n * sizeof(float);
  int devId = 0;
  if (argc > 1) devId = atoi(argv[1]);
  cudaDeviceProp prop;
  checkCuda( cudaGetDeviceProperties(&prop, devId));
  printf("Device : %s\n", prop.name);
  checkCuda( cudaSetDevice(devId) );
  // allocate pinned host memory and device memory
  float *a, *d_a;
  checkCuda( cudaMallocHost((void**)&a, bytes) );      // host pinned
  checkCuda( cudaMalloc((void**)&d_a, bytes) ); // device
  float ms; // elapsed time in milliseconds
  // create events and streams
  cudaEvent_t startEvent, stopEvent, dummyEvent;
  cudaStream_t stream[nStreams];
  checkCuda( cudaEventCreate(&startEvent) );
  checkCuda( cudaEventCreate(&stopEvent) );
  checkCuda( cudaEventCreate(&dummyEvent) );
  for (int i = 0; i < nStreams; ++i)
    checkCuda( cudaStreamCreate(&stream[i]) );
  // baseline case - sequential transfer and execute
  memset(a, 0, bytes);
  checkCuda( cudaEventRecord(startEvent,0) );
  checkCuda( cudaMemcpy(d_a, a, bytes, cudaMemcpyHostToDevice) );
  kernel<<<n/blockSize, blockSize>>>(d_a, 0);
  checkCuda( cudaMemcpy(a, d_a, bytes, cudaMemcpyDeviceToHost) );
  checkCuda( cudaEventRecord(stopEvent, 0) );
  checkCuda( cudaEventSynchronize(stopEvent) );
  checkCuda( cudaEventElapsedTime(&ms, startEvent, stopEvent) );
  printf("Time for sequential transfer and execute (ms): %f\n", ms);
  printf("  max error: %e\n", maxError(a, n));
  // asynchronous version 1: loop over {copy, kernel, copy}
  for (int i = 0; i < nStreams; ++i) {
    int offset = i * streamSize;
    checkCuda( cudaMemcpyAsync(&d_a[offset], &a[offset],
                               streamBytes, cudaMemcpyHostToDevice,
                               stream[i]) );
    kernel<<<streamSize/blockSize, blockSize, 0, stream[i]>>>(d_a, offset);
    checkCuda( cudaMemcpyAsync(&a[offset], &d_a[offset],
                               streamBytes, cudaMemcpyDeviceToHost,
                               stream[i]) );
  printf("Time for asynchronous V1 transfer and execute (ms): %f\n", ms);
  // asynchronous version 2:
  // loop over copy, loop over kernel, loop over copy
                               stream[i]) );
                               stream[i]) );
  printf("Time for asynchronous V2 transfer and execute (ms): %f\n", ms);
  // cleanup
  checkCuda( cudaEventDestroy(startEvent) );
  checkCuda( cudaEventDestroy(stopEvent) );
  checkCuda( cudaEventDestroy(dummyEvent) );
    checkCuda( cudaStreamDestroy(stream[i]) );
  cudaFree(d_a);
  cudaFreeHost(a);
  return 0;
Thank you :) .
Also, cudaMallocManaged will not allow you to allocate more memory than the device has. I did some initial testing of managed memory in CUDA 6 here:
https://devtalk.nvidia.com/default/topic/695408/first-impressions-of-cuda-6-managed-memory
