Hi AlpaSim Challenge Team,
I would like to clarify whether a particular use of the route input is permitted
in the AlpaSim E2E Closed-Loop Challenge 2026.
My understanding is that, for the competition, the Driver receives route
waypoints beginning approximately 40 m ahead of the ego vehicle
(route_start_offset_m = 40.0).
I also understand from Issue #138 that the route is constructed using the
recorded ego path over the full recording to determine the lane sequence, and
then represented using the corresponding lane centerlines.
Related discussion:
Suppose a Driver maintains state throughout one rollout and does the following:
- Stores each
submit_routeobservation over time. - Uses the corresponding ego-motion observations to transform each route
segment from its timestamp-specific rig frame into a persistent/common frame. - Fuses the overlapping route segments observed at different timestamps.
- Uses this accumulated route representation as an input to the driving policy.
Because the route window moves forward as the ego vehicle progresses, after
enough travel this can potentially reconstruct a substantial portion of the
lane-level route selected from the recorded trajectory, including portions
that were previously outside the current 40–80 m route window.
My questions are:
Is retaining and temporally accumulating
submit_routeobservations within
a rollout allowed under the competition rules? -
Is transforming historical route observations using received ego-motion and
building a persistent route map considered an intended use of the Driver
observation contract? -
Or would this be considered unintended ground-truth leakage / exploitation
because the route itself was derived from the recorded ego trajectory? -
If it is currently allowed, should contestants expect the same route
semantics in the final evaluation after the competition configuration is
frozen?
We would like to clarify this before using such a mechanism in our submission.
Thank you.
