I was trying to write some code that would do Alpha Compositing of one webm file over the top of another webm file using GStreamer.
It didn’t work. I wrote a Stack Overflow Post here:-
I was wondering if anyone could provide some example code that alpha composites one webm video file over another webm video file using GStreamer and Python ?
I would like to try and use GStreamer to composite webm videos on top of each other instead of using FFMPEG Filter Complex Overlay.
Useful so I can compose and render videos using GPU optimised GStreamer instead of using FFMPEG and CPU.
Application is in Cloud Based VIdeo Composition and Rendering for Video Advertising
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Hardware Platform :- GPU
DeepStream Version :- Not installed
GStreamer version:- GStreamer Core Library version 1.16.3
JetPack Version:- This is not for Jetson, will be on AWS Cloud eventually.
TensorRT Version:- Not installed
NVIDIA GPU Driver Version:- NVIDIA-SMI 470.129.06 Driver Version: 470.129.06 CUDA Version: 11.4
GPU:- Quadro RTX 3000 6GB
Issue Type:-
How to reproduce the issue:-
Install GStreamer, and PyGObject, and PyCairo, copy code above, and run.
Requirement details:- Ubuntu 20.04.4 LTS, GStreamer trying to use nvcompositor to composite two webm files on top of each other.
Is there a way to overlay or composite a webm vp9 video over the top of another webm vp9 video using GStreamer or another NVidia library so that it can be processed on the GPU ?
If there isn’t, is there a way I can make a voluntary contribution to NVidia code so that this functionality can be reviewed and pulled into master ?
