• Hardware Platform (Jetson / GPU) → T4
• DeepStream Version → 5.0
• TensorRT Version → 7.0
• NVIDIA GPU Driver Version (valid for GPU only) → 440.82
So, I have been able to convert alpr-unconstrained to TensorRT and getting the correct infer results.
Now, I want to detect LP on top of objectDetector_Yolo, I have been able to create a pipeline with back to back detectors. The problem is the postprocessing of LPD output.
Do, I have to write the port all the post processing code in C++ from NumPy/Python which is very tedious task and my inexperience in C++ make it even more difficult. Or can I use python itself to parse the output.
Below is the output parsing in python:
def reconstruct(I,Y,out_size,threshold=.9):
net_stride = 2**4
side = ((208. + 40.)/2.)/net_stride # 7.75
Probs = Y[...,0]
Affines = Y[...,2:]
rx,ry = Y.shape[:2]
ywh = Y.shape[1::-1]
iwh = np.array(I.shape[1::-1],dtype=float).reshape((2,1))
xx,yy = np.where(Probs>threshold)
WH = getWH(I.shape)
MN = WH/net_stride
vxx = vyy = 0.5 #alpha
base = lambda vx,vy: np.matrix([[-vx,-vy,1.],[vx,-vy,1.],[vx,vy,1.],[-vx,vy,1.]]).T
labels = []
for i in range(len(xx)):
y,x = xx[i],yy[i]
affine = Affines[y,x]
prob = Probs[y,x]
mn = np.array([float(x) + .5,float(y) + .5])
A = np.reshape(affine,(2,3))
A[0,0] = max(A[0,0],0.)
A[1,1] = max(A[1,1],0.)
pts = np.array(A*base(vxx,vyy)) #*alpha
pts_MN_center_mn = pts*side
pts_MN = pts_MN_center_mn + mn.reshape((2,1))
pts_prop = pts_MN/MN.reshape((2,1))
labels.append(DLabel(0,pts_prop,prob))
final_labels = nms(labels,.1)
TLps = []
return final_labels
The problem is C++ buffers are 1D array and the post processing in original code is done in NumPy nd array. Thanks in advance.
