Ambiguity function, best way to approach this in cuda?
removed
removed
You can make code tags by using
tags.
Thank you for the syntax tags.
I removed the code. Made a test where the main application is not executing the kernel and just copying memory back and forth = doing nothing essentially, it was at least 20x slower than executing it via openmp #parallel for … so GPU brings no benefit.
-M
