I have five camera streams on 30 fps, publishing for each image a message on the AMQP broker.
The expected throughput would be 150 msg/sec, but unforunately it reaches only up to 93 msg/sec. I verified that the asynchronous send is executed in the broker plugin (self->nvds_msgapi_send_async).
Furthermore I checked in which rate the function nvds_msgapi_send_async() in gst_nvmsgbroker_render() is called. It is very exactly 150/s. So I can exclude, that anything before is causing the delay.
When I lower the fps to for example 6, I get the expected 5*6=35 msg/sec on the broker.
I built a quick example in python, that sends the the same message size to rabbitmq and there I can easily reach a throughput of 150 msg/sec, even more.
The message is not big. Here and example:
json_sample = {
"version": 1,
"sensorId": 0,
"frame_id": 122,
"frame_width": 1280,
"fram_height": 720,
"objects": [],
"stamp": {"secs": 12222222, "nsecs": 12222222}
Do you have any idea, why the throughput is so bad?
I would appreciate some feedback.
