I am ‘extremely’ new to CUDA. Would it be possible for you to share your bi- (tri-) linear interpolation code for CUDA… or direct me to some web/ book/ resources for interpolation.
The programming guide has been somewhat unclear in terms of floating point interpolations.
As I mentioned, I use the texture unit to get bilinear interpolation - just use cudaFilterModeLinear on a 2D float texture. I haven’t written explicit bi- or trilinear interpolation code in CUDA.
Wikipedia has a decent (but short) description on it:
Writable textures? I don’t think you’ll see that any time soon, textures are optimised for reading and should be. If you need to write, you can just as well use normal linear memory, as the cache will only get in the way.
You can “write” to a cudaArray texture by writing to a global memory pointer, then doing a fast device memcpy to update the cudaArray. The time for the copy is tiny, but for large textures the memory cost of the double buffer might be annoying.
If you are using 1d textures bound to linear memory, you can write back to that same memory without any overhead or penalty.
Don’t use textures. You’ll lost the texture cache benefit, but if your access pattern is predictable you can generally come up with an algorithm that coalesces reads
Use textures to read the data from, write to a global memory array. After your kernel, use a (fast!) device to device call to copy the memory to the texture.
It depends on the specific case which one is best.
Can I belatedly join this thread to says that 3D textures is a feature I would really like to see added to cuda, and if it comes without emulation, so be it.
