Hello. Everyone in nVIDIA.
Jetson_TX 2 is inserted on a custom carrier board on which TX 1 is activated.
There is a problem that the empty TX 2 can not be recognized on the PC from the USB 2 _ OTG port.
In the empty TX 1, the PC notifies the device manager that it recognized an unknown device, but there is no response in TX 2.
Application / DeepLearning processing can be executed with this custom carrier board. USB3 / GbE is also the board that is operating.
When exchanging to TX 2, the carrier board power is turned on in the auto power on mode.
Voltage of VDD_RTC has also been observed at 2.54 V from TX2.
RESET_OUT / IN is 1.8 V.
It seems that only Tegra_X 2 is not running.
If Maxim’s IC runs and Tegra does not start, where should you doubt?
If there is a precedent, please tell me.
that’s all.
