An error occurred while burning the chip. What should I do?
刷机时,出现了如下错误:
下一步应该怎么做
我这边保存了一些日志,看看有你需要的吗。
Hi qiliangqingchun,
Could you help to provide the full SDKM log for further check?
Yes, please upload sdkm-2023-03-07-16-05-49.log as file here.
Hi qiliangqingchun,
In the log, we could see that “sudo apt update” failed because of host environment apt repository error:
16:10:13.253 - error: NV_L4T_FILE_SYSTEM_AND_OS_T210_COMP@JETSON_NANO_TARGETS: Err:24 Index of /shutter/ppa/ubuntu bionic Release
16:10:13.254 - info: NV_L4T_FILE_SYSTEM_AND_OS_T210_COMP@JETSON_NANO_TARGETS: 404 Not Found [IP: 185.125.190.52 80]
16:10:18.862 - error: NV_L4T_FILE_SYSTEM_AND_OS_T210_COMP@JETSON_NANO_TARGETS: E: The repository ‘Index of /shutter/ppa/ubuntu bionic Release’ does not have a Release file.
Can you please fix this error, manually run “sudo apt update” command in a terminal window, make sure it is successful, then retry installation with SDK Manager?
