An Even Easier Introduction to CUDA
Hello, I’m new to cuda, also new to C++, i’m having a weird issue with the sample, the GPU code is 3x slower than the CPU one, here is the code (I just changed int N = 1<<20; to int N = 1<<25;)
CPU CODE :
#include <iostream>
#include <math.h>
using namespace std;
// function to add the elements of two arrays
void add(int n, float *x, float *y)
  for (int i = 0; i < n; i++)
      y[i] = x[i] + y[i];
int main(void)
  unsigned int N = 1<<25; // 1M elements
  std::cout << "Iterations : " << N << "\n";
  float *x = new float[N];
  float *y = new float[N];
  // initialize x and y arrays on the host
  for (int i = 0; i < N; i++) {
    x[i] = 1.0f;
    y[i] = 2.0f;
  // Run kernel on 1M elements on the CPU
  add(N, x, y);
  // Check for errors (all values should be 3.0f)
  float maxError = 0.0f;
    maxError = fmax(maxError, fabs(y[i]-3.0f));
  std::cout << "Max error: " << maxError << std::endl;
  // Free memory
  delete [] x;
  delete [] y;
  return 0;
GPU CODE :
#include <iostream>
#include <math.h>
// Kernel function to add the elements of two arrays
__global__
  int index = threadIdx.x;
  int stride = blockDim.x;
  for (int i = index; i < n; i += stride)
      y[i] = x[i] + y[i];
int main(void)
  int N = 1<<25;
  float *x, *y;
  // Allocate Unified Memory – accessible from CPU or GPU
  cudaMallocManaged(&x, N*sizeof(float));
  cudaMallocManaged(&y, N*sizeof(float));
    x[i] = 1.0f;
    y[i] = 2.0f;
  // Run kernel on 1M elements on the GPU
int blockSize = 256;
int numBlocks = (N + blockSize - 1) / blockSize;
add<<<numBlocks, blockSize>>>(N, x, y);
  // Wait for GPU to finish before accessing on host
  cudaDeviceSynchronize();
  // Free memory
  cudaFree(x);
  cudaFree(y);
  return 0;
GPU : RTX4800
compile commands :
GPU code :
 nvcc .\test2.cu -o test2 -arch=sm_90a
CPU code :
  nvcc .\test.cu -o test
CPU RESULT :
PS C:\Users\llefe\CUDA> Measure-command {.\test.exe}
Days              : 0
Hours             : 0
Minutes           : 0
Seconds           : 0
Milliseconds      : 892
Ticks             : 8920678
TotalDays         : 1,03248587962963E-05
TotalHours        : 0,000247796611111111
TotalMinutes      : 0,0148677966666667
TotalSeconds      : 0,8920678
TotalMilliseconds : 892,0678
GPU RESULT :
PS C:\Users\llefe\CUDA> Measure-command {.\test2.exe}
Days              : 0
Hours             : 0
Minutes           : 0
Seconds           : 2
Milliseconds      : 882
Ticks             : 28823809
TotalDays         : 3,33608900462963E-05
TotalHours        : 0,000800661361111111
TotalMinutes      : 0,0480396816666667
TotalSeconds      : 2,8823809
TotalMilliseconds : 2882,3809
Posting in case anyone else runs into the issue where increasing the number of blocks beyond 1 fails to improve the profiling / timing reported for the add() call. Comparing the code in the post with the vectorAdd example in the cuda-samples repo, I noticed that the calls for memory allocation were different. In the blog post, it was cudaMallocManaged, whereas in the vectorAdd example, it was cudaMalloc and cudaMemcpy. This made all the difference to the profiler, and, with the latter memory strategy, I saw the expected performance pickup.
==186921== Profiling application: ./add_test
==186921== Profiling result:
            Type  Time(%)      Time     Calls       Avg       Min       Max  Name
 GPU activities:   59.39%  1.2993ms         2  649.65us  628.58us  670.72us  [CUDA memcpy HtoD]
                   39.16%  856.87us         1  856.87us  856.87us  856.87us  [CUDA memcpy DtoH]
                    1.45%  31.712us         1  31.712us  31.712us  31.712us  add(int, float*, float*)
==186266== Profiling application: ./add_grid
==186266== Profiling result:
 GPU activities:  100.00%  3.0770ms         1  3.0770ms  3.0770ms  3.0770ms  add(int, float*, float*)
I’m very new to CUDA, and certainly wouldn’t know if things have evolved since the 2017 post, but is this the expected behavior in late 2023?
thanks!
Dustin
So I’m trying to run the collab notebook linked to from this course (direct link to the collab notebook) and the GPU parts just aren’t working. The CPU program works fine, but for all of the GPU programs (without any changes to the code) you end up with a maxError of 1 and if you print out the contents of y it’s all just 2 even after the kernel has been run and the synchronisation called. Feels like the kernel either isn’t actually getting run, or the changes made on the GPU aren’t actually reflected on the CPU.
Had to change the Mem prefetch code little bit for cuda 13.0
cudaMemLocation hostLoc;
hostLoc.type = cudaMemLocationTypeHost;
cudaMemPrefetchAsync(x, N*sizeof(float), hostLoc, 0);
cudaMemPrefetchAsync(y, N*sizeof(float), hostLoc, 0);
But I didn’t notice significant difference after adding prefetching.
Without Pre fetching
Time (%) Total Time (ns) Instances Avg (ns) Med (ns) Min (ns) Max (ns) StdDev (ns) Category Operation
75.4 1381541 1 1381541.0 1381541.0 1381541 1381541 0.0 CUDA_KERNEL add(int, float *, float *)
20.3 371721 139 2674.3 959.0 767 32288 5376.0 MEMORY_OPER [CUDA memcpy Unified Host-to-Device]
4.4 79828 24 3326.2 1103.5 383 18400 5299.6 MEMORY_OPER [CUDA memcpy Unified Device-to-Host]
With Pre fetching
An alternative for the change to the cudaMemPrefetchAsync() call in 13.0 is:
cudaMemPrefetchAsync(x, N * sizeof(float), { .type = cudaMemLocationTypeDevice, .id = 0 }, 0);
cudaMemPrefetchAsync(y, N * sizeof(float), { .type = cudaMemLocationTypeDevice, .id = 0 }, 0);
@swarankar.ani24 I think you have hostLoc.type set wrong. Try setting it to cudaMemLocationTypeDevice.
I got a significant speedup on my RTX A400.
Nice tutorial @Mark_Harris and thanks for the useful nsys_easy script! Just a couple of notes from my experiments with the RTX A400.
Execution Time for add() kernel (ns) Speedup
Single Thread 70,258,824 1x
Single Block, Multiple Thread 1,374,667 51x
Multiple Block, Multiple Thread 145,149 484x
I noted that the speedup between single block and multi block is about 9.5x, which is greater than the multiprocessor count in the A400. However, the bandwidth achieved in the multi-block case was around 86GB/s, which is very close to the 96GB/s memory bandwidth from the datasheet.
I’m curious as to whether it would be better to have one thread per array element, or if the number of blocks was set smaller and each thread allowed to calculated more than one value of y. I would have thought there was a little overhead in setting up a new GPU thread/for loop versus calculating a couple of additional values within the for loop. But it seems that the reverse is true and smaller numbers of blocks perform worse. Interested in your thoughts on this.
Hi, I think there is an inconsistency in the first __global__ kernel snippet, which includes a sum parameter that is later omitted from the complete code. Could the earlier parts be refactored to not include references to sum? Thank you for considering!
Despite being written by a top expert — or perhaps because of that — the article is full of typos and subtle “gotchas” that can easily confuse beginners. You must ignore the claim that everything works on Windows, WSL, or Linux. In practice, Linux is the least painful option, assuming your distribution plays nicely with your GPU and CUDA setup. CUDA tooling is notoriously difficult, and very little works out of the box.
The article also dives into the Nsight profiler, which is an advanced and fairly intimidating tool. It can be difficult both to configure correctly and to interpret meaningfully, especially for newcomers.
