An issue where only a black screen appears after installing Jetpack 5.1.2 using sdk manager in AGX Orin
An issue where only a black screen appears after installing Jetpack 5.1.2 using sdk manager in AGX Orin.
I’m now suspecting that the situation stays in recovery mode . However, I don’t know how to solve this situation, so I’m posting on the forum. Please confirm.
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_AGX_Orin_modules_2023-08-07_13-14-39.zip (171.3 KB)
Process :
1.Connect micro USB to Bus 003 Device 032: ID 0955:7223 NVIDIA Corp. Check APX
  1. I installed Jetpack 5.1.2 on my AGX Orin via sdk manager.
  2. Check the installation success message in the log
  3. When AGX Orin is rebooted, only a black screen is displayed
are you still able to login via serial console?
In case you are using an HDMI monitor, make sure it’s a active DP-HDMI cable.
I am using HDMI-HDMI.
This is my Advantech Orin-AGX .
Then you should contact AdvanTech directly for help.
