Hello, I’m trying to change the code of deepstream-test1 to forward camera input of UDP and TCP stream.
I successfully found GStreamr command of UDP,and I try to write the Receiver in deepstream-test1.c:
Sender:
$ gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! “video/x-raw,format=I420,width=640,height=480,framerate=(fraction)30/1” ! queue2 ! nvvideoconvert ! ‘video/x-raw(memory:NVMM), width=(int)1280, height=(int)480, format=(string)I420’ ! nvv4l2h264enc ! “video/x-h264, stream-format=(string)byte-stream” ! h264parse ! rtph264pay mtu=1400 ! udpsink host=127.0.0.1 port=5000 sync=false async=false
Receiver:
$ gst-launch-1.0 udpsrc port=5000 ! application/x-rtp,encoding-name=H264,payload=96 ! rtph264depay ! h264parse ! queue ! omxh264dec ! nvoverlaysink
sync=false async=false -e
But I didn’t find the Gstream command of TCP. Could someone give me the code of TCP Sender and TCP Receiver?
Thanks in advance!
