• Hardware Platform (Jetson / GPU) - Jetson Nano • DeepStream Version - 6.0.1 • JetPack Version (valid for Jetson only) - 4.6.2 • TensorRT Version - 8.2 • NVIDIA GPU Driver Version (valid for GPU only) 10.2 • Issue Type( questions, new requirements, bugs)
I use Dahua IP cameras connected via a POE switch. I’ve successfully obtained RTSP stream formats and verified their accessibility with OpenCV. However, when attempting to use DeepStream in Python, I encountered an error: “Warning: gst-resource-error-quark: Could not read from resource”.
Upon inspecting the RTSP streams using gst-discoverer-1.0 "rtsp://username:password@ipaddress:port/cam/realmonitor?channel=1&subtype=0", I received a “Analyzing URI timed out” message.
I’m uncertain whether the mentioned issue can be reproduced.
can you able to resolve this issue or give any suggestion?
