Server : DEll PowerEdge R740 (48 cores ) (with hyperthreading enabled 96 vcpu cores) (RAM: 384 GB)
GPU : NVIDIA A16 4 cards
OS : Ubuntu 20.04.6 LTS (x86_64)
Anbox-cloud-appliance version : 1.19.2
I am evaluating anbox-cloud for cloud gaming on the above mentioned server (single node baremetal server).
I have created anbox application with a game apk (subway_surfers) using the dashboard .
I have also created another anbox application with a test apk (which plays the recorded game video session as soon as it is launched) for creating loadtest sessions.
Using the following bash script to launch the loadtest sessions :
#!/bin/bash
For loop with number range
for i in {0…60}
do
anbox-cloud-tests.benchmark -t 30 --insecure-tls --screen-width=1280 --screen-height=720 --screen-fps=60 --application=testanbox --url=https:// --auth-token=“” &
sleep 10
done
Once the loadtest sessions are active, from dashboard I am creating a session for the game application (subway_surfers) and checking the play experience.
Under load it is observed that there are occasional fps drops .
I have also attached some screenshots captured under load.
What is the reason for fps drops affecting gameplay experience even when cpu usage (50%) has not peaked and GPU usage (40%) has not peaked?
Please suggest if there are any recomended nvidia settings to avoid fps drop under load ?
Also please suggest if there are any anbox cloud specific settings to avoid fps drop under load ?
With the above mentioned server and GPU cards, what is the number of maximum concurrent sessions that could be run with 720p and 60fps cloud gaming sessions.
Srinidhi
anbox_loadinfo.zip (742.9 KB)
