Hi I am using Android 12.1 (LineageOS 19.1) on the Jetson TX2 Nx and am facing some gpu related issues.
I am running into ANR’s during high graphic usage. I believe the issue is in the Nvidia gpu memory stack caused by memory pressure (leak or fragmentation) that would prevent the gpu from allocating video buffers. Logs: Jeton nx2 gpu logs - Pastebin.com
As the current solution depends on open source efforts is there a plan from Nvidia to support a modern Android BSP? Or any one willing to help support debugging issues using existing drivers.
