I am getting my dmesg spammed by what appears to be a usb (?) module, I can’t trace it back to anything, and this thing makes reading dmesg and syslog impossible:
android_work: did not send uevent
Any idea what it is and how to disable it?
I’m using the latest Jetpack on a TX2.
I’m using 4.6, part of the dmesg is attached below (it spams too fast for me to copy paste much of it).
However I think I figured it out, I had the micro usb connected from when I flashed the TX2. The USB was connected to my PC, and I suspect the TX2 was trying to mount it as an android device for some bizzare reason. I haven’t seen it happen before to a TX2, TK1 or Jetson Nano.
+0.000042] CPU2: shutdown [3450/4085]
[ +0.002747] psci: CPU2 killed (polled 0 ms)
[ +0.084872] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ +0.080138] gpio tegra-gpio wake18 for gpio=101(M:5)
[ +0.002815] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ +0.022418] wifi_platform_bus_enumerate device present 1
[ +0.013579] zram: Added device: zram0
[ +0.001540] zram: Added device: zram1
[ +0.003756] zram: Added device: zram2
[ +0.003535] wifi_platform_bus_enumerate device present 0
[ +0.001212] F1 signature read @0x18000000=0x17214354
[ +0.001441] zram: Added device: zram3
[ +0.027014] android_work: did not send uevent (0 0 (null))
[ +0.007207] zram0: detected capacity change from 0 to 1030017024
[ +0.007623] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ +0.000809] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ +0.000098] wifi_platform_get_mac_addr
[ +0.016957] ids dhd_log_netlink_init
[ +0.000772] wl_event_handler :
[ +0.000005] tsk Enter, tsk = 0xffffffc1cca81a90
[ +0.000006] wl_create_event_handler(): thread:wl_event_handler:15f5 started
[ +0.000919] dhd_attach(): thread:dhd_watchdog_thread:15f8 started
[ +0.001521] dhd_attach(): thread:dhd_dpc:15f9 started
[ +0.002223] dhd_attach(): thread:dhd_rxf:15fa started
[ +0.000008] dhd_deferred_work_init: work queue initialized
[ +0.000812]
Dongle Host Driver, version 1.201.82 (r)
Compiled from
[ +0.008272] Register interface [wlan0] MAC: 00:04:4b:8c:5c:52
[ +0.000006] dhd_prot_ioctl : bus is down. we have nothing to do
[ +0.000180] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 65
[ +0.001055] wifi_platform_set_power = 0
[ +0.010953] Adding 1005872k swap on /dev/zram0. Priority:5 extents:1 across:1005872k SS
[ +0.005277] zram1: detected capacity change from 0 to 1030017024
[ +0.024589] Adding 1005872k swap on /dev/zram1. Priority:5 extents:1 across:1005872k SS
[ +0.004012] zram2: detected capacity change from 0 to 1030017024
[ +0.004828] android_work: did not send uevent (0 0 (null))
[ +0.011506] Adding 1005872k swap on /dev/zram2. Priority:5 extents:1 across:1005872k SS
[ +0.004365] zram3: detected capacity change from 0 to 1030017024
[ +0.015820] Adding 1005872k swap on /dev/zram3. Priority:5 extents:1 across:1005872k SS
[ +0.052427] android_work: did not send uevent (0 0 (null))
[ +0.006969] android_work: did not send uevent (0 0 (null))
[ +0.007009] android_work: did not send uevent (0 0 (null))
[ +0.091111] android_work: did not send uevent (0 0 (null))
[ +0.225122] tegra-vi4 15700000.vi: subdev ov5693 2-0036 bound
[ +0.215016] Bridge firewalling registered
[ +0.064731] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ +0.025237] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ +0.003558] bcpu-throttle-alert cooling device registered.
[ +0.000308] mcpu-throttle-alert cooling device registered.
[ +0.001362] gpu-throttle-alert cooling device registered.
[ +0.342914] tegradc 15210000.nvdisplay: blank - powerdown
[ +0.046857] android_work: did not send uevent (0 0 (null))
[ +0.021033] android_work: did not send uevent (0 0 (null))
[ +0.035067] android_work: did not send uevent (0 0 (null))
[ +0.025186] android_work: did not send uevent (0 0 (null))
The same message goes on for 4,000 lines, until I disconnected the USB cable, and was spamming at many times a second:
+0.014020] android_work: did not send uevent (0 0 (null))
[ +0.021030] android_work: did not send uevent (0 0 (null))
[ +0.007007] android_work: did not send uevent (0 0 (null))
[ +3.118781] android_work: did not send uevent (0 0 (null))
[ +0.023844] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ +0.000027] tegra-xudc-new 3550000.xudc: vbus state: 0
[ +0.000020] tegra-xudc-new 3550000.xudc: device mode off: 0
[ +0.000862] tegra-usb-cd usb_cd: notification status (0xa, 0x0)
[ +0.000016] tegra-usb-cd usb_cd: disconnected USB cable/charger
[ +0.000026] tegra-xudc-new 3550000.xudc: active: 1 => 0
[ +0.000021] tegra-xudc-new 3550000.xudc: entering ELPG
[ +0.004424] tegra-xudc-new 3550000.xudc: entering ELPG done
What’s the module/library that this corresponds to?
