androidmanifest.xml isnt found ?
hello
when i try to “import android project” it scans my folders for all files that are checked by default but it gives an error msg “androidmanifest.xml wasnt found” but i see he found it when browsing for the files he selected for import, any idea how to avoid this bug ?
thanks
Hi - this issue is being addressed in an upcoming release.
Cheers!
I have Tegra 1R5 version for MS Visual Studio 2015 and problem still exists.
I am starting new projects by importing existing android project with ndk
and get same AndroidManifest.xml “not found” error
by steps:
  1. file-> New project → importing android NDK project:
  1. error after scanning the sources folder:
Hi Nikolay,
That is due to file layout difference. We assume that AndroidManifest.xml is at the rootDir.
For a workaround, you can just copy or mklink androidManifest.xml to rootDir.
Victor
Hi, thank you for your email. After I’ve copied Manifest file to rootDir it was imported fine.
