Angle parameterization
Hi!
In my work, I want to try to parameterize the model due to the angle of rotation of a certain cutout in my design. But I ran into a problem that I cannot comprehend. There were no problems with parameterizations, but the rotation did not give in (I attach the logs and code)
problem (2.4 KB)
my_checkerEllipse.py (9.6 KB)
Hey, sorry for the late reply to this. I looked into this and I think I see the issue now. When we create the ElliCylinder we parameterized the SDF with a value named theta and this was causing an issue when you parameterized with the same variable name. We will look into a permanent solution for this but for now I renamed your parameter theta and it runs fine.
