I try animating meshes in Omniverse Create v 2022.3.0.
I have main scene in a root layer and I have delta layer for my changes.
When I create Cube or Sphere and animate it’s position with Curve Editor in the Root Layer - everything works. When I switch to my delta layer (make it authoring) and create another set of these objects, and animate them in the same way - animation does not work. Dragging the slider in the Curve editor makes no effect, although I’ve set several key frames with various changes to prim’s properties (location).
I can see a warnings in a viewport (written in a yellow rounded bar):
“Overridden in multiple layers, see log for details.”
My logs are full of lines like
[Warning] [omni.kit.widget.layers.layer_model] /World/Torus_01.xformOp:translate is overridden in a stronger layer (Root Layer).
[Warning] [omni.kit.notification_manager.manager] Overridden in multiple layers, see log for details.
[Warning] [omni.kit.notification_manager.manager] Overridden in a stronger layer (Root Layer).
