Animation / Action Graph
I am new here and I was wondering if there is a tutorial available that explains the process of creating “path - curve” and “path - points” samples using Animation Graph and Action Graph in Machinima?
Thank you,
@csevtekin i personally haven’t come across tutorials going over the specifics of those two nodes. if you don’t mind me asking, what are you looking to achieve?
as a side note, i would probably suggest working with action/animation graph in Composer since Machinima may not be in development anymore.
Hi @Simplychenable:
Thank you for the information. I will work with the Action/Animation Graph in Composer.
I opened the Sample tab in Machinima and noticed there are two sample projects where you can move the character using path-points and path-curve.
Path - Points:
For target points, under the Stage tab, there are AnimationGraph & PathPoints. It seems like there is a link between them. I was trying to add more points in the scene for the character to follow, but I just don’t know how link those points to the character by using Animation graph nodes.
Path - Curve:
The same goes for the path-curve; I don’t know how to make the character follow any curve other than what they use in the sample project.
I assume these points are used for creating curve path. Again I don’t know how to link them via Animation graph node.
My ultimate goal is to calculate the time each character spends from point A to point B and the path length for each character. Eventually, I aim to determine the overall time and overall path length for each character to follow during the animation. I hope there is a way to do those calcs.
Thank you,
