Animation in XR
If I load the Flow fire simulation in Create, I can play it and use Table AR to view it. This is awesome Volumetric fire playing in realtime on my iPad.
But I can’t get this to work in VR.
If I save the scene in create and load it into Create XR, the fire is not visible.
Create XR has play and pause, but not timeline extension. How do you control animations?
Brad Carvey
I will give this a try but you may simply have to enable the Flow extension in Create XR.
In Window > Extensions
Search for flow and activate the extension.
Keep in mind that if you use path tracing mode you may need to change a default setting for the simulation to update properly in the viewport.
