Is it possible to power 6 Jetson Nanos with an Anker PowerPort 6? It should be able to output 5v 2.4A on each port at the same time.
Yes, if it will actually support that, then that would work. This is more a question of the Anker than the Nano itself.
I have a power port 6 that will power a cluster of Pi’s without a problem. It did not power the nano, sorry. You could try another model, but there are no guarantees.
(hit quote instead of edit on mobile)
