Announcement: MDL SDK 2024.1.1 released
Get the update on MDL SDK | NVIDIA Developer and GitHub - NVIDIA/MDL-SDK: NVIDIA Material Definition Language SDK (on branch release/2024.1).
MDL SDK 2024.1.1 (381500.4681): 31 Mar 2025
Added and Changed Features
  • General
    • MDL Python Bindings:
      • Improve type hints for *_as(type, ...) functions.
    • On Windows, the MSVC runtime flavor is now controlled by the new options
      MDL_MSVC_DYNAMIC_RUNTIME and MDL_MSVC_DYNAMIC_RUNTIME_DXR_EXAMPLE. Support
      for the old option MDL_MSVC_DYNAMIC_RUNTIME_EXAMPLES has been removed.
    • The severity filter for log messages is now also applied to delayed
      messages, i.e., the first two messages concerning the location and version
      information of the library.
    • Added a new context option “handle_filename_conflicts” to control naming of
      resources during export. See IMdl_impexp_api::export_module() for details.
    • Improved performance of code generation by the MDL backends on Linux by 3-4%.
    • Added SECURITY.md file with instructions how to report security issues.
    • Added ::nvidia::distilling_support to the example content such that it can be
      used by the MDL Core examples.
    • Classified all plugins as cmake module libraries instead of shared
      libraries. This avoids that they get used incorrectly with
      target_link_libraries() and eliminates the .lib files on Windows.
    • Linking the MDL Core/SDK library is deprecated (this also happens implicitly
      when using target_link_libraries(). The cmake library type will be changed
      from SHARED to MODULE in a future release. Likewise, the corresponding
      import libraries on Windows will be removed. Users should access the MDL
      Core/SDK library using LoadLibrary()/GetProcAddress() or dlopen()/dlsym()
      instead (as it is done in all examples). Cmake users should use:
      get_target_property(SOME_VAR mdl::mdl_sdk INTERFACE_INCLUDE_DIRECTORIES)
      target_include_directories(your_target PRIVATE ${SOME_VAR})
      (similarly for mdl::mdl_core).
    • Added the linker option --strip-all/-x for release builds on Linux/MacOS.
  • MDL Compiler and Backends
    • The compiler now obeys the target_material_model annotation when used on material
      presets. This allows to make a target material from a preset, even if the original material
      is not. This implements user expectations.
  • MDL SDK examples
    • Added new dependency_inspector example:
      • It lists all file dependencies of an MDL module for direct and (optionally) indirect
        imports and resources.
    • Example modules:
      • Completely refactored this example that now extends its functionality.
      • Added options to set MDL search paths and load/scan user selected modules.
      • Added filter option to select which information to output from a module: imports,
        types and constants definitions, function and material definitions, resources.
      • Added option to scan indirect dependencies and resources from imported modules.
      • Added option to display the default values, temporaries and body of selected function
        and material definitions.
    • Example DXR:
      • Updated MaterialX SDK to 1.39.3.
      • Added option to override selected materials in the scene:
        --mat_selective <selector> <qualified_name>”.
      • Added option to control the camera exposure for matching certain render tests:
        --cam_exposure”.
      • Added support for subsurface scattering by implementing the Henyey-Greenstein
        phase function.
      • Added option to control the subsurface scattering path length: “--max_sss_steps”.
    • Third-party dependencies:
      • Disabled XInput support in the ImGui compilation.
  • MDL Core examples
    • Shared:
      • Added new Distiller_helper helper class. It simplifies the context creation and
        procedure required for distilling an MDL material using Core API.
    • Example code_gen:
      • Added option to distill an MDL material to a given material target model.
Fixed Bugs
  • MDL 1.10 Language Specification
    • Fixed minor typographic errors and improved wording.
  • General
    • Improved the handling of invalid re-use of names of DB elements eligible
      for garbage collection. As a consequence, some of these uses are considered
      safe now. See “Database Access” in the API reference documentation for
      details.
    • Fixed export of MDL modules with animated and/or uvtile textures if the
      texture file exists already. Now we generate a unique filename (as for
      plain textures and other resources) instead of unconditionally overwriting
      an existing file.
    • Fixed entity resolver returns only a file name (without the directory) when resolving
      UDIM sets on disk.
    • Fixed wrong error message “index of declarative types must be uniform” that was issued
      by the compiler if the index of an declarative array access was a constant.
    • Fixed wrong error messages issued that a (constant) array cannot be converted into a
      uniform array.
    • Fixed missing backend support for implicit conversion between declarative structs of the
      same category in default argument, causing a crash when target code is generated.
    • Fixed missing type import causing assertions in debug build.
    • Added missing support for the hidden argument of the decl_cast intrinsic function.
    • Fixed several problems with the auto import of entities in MDL, most of them now visible
      by the user, but causing assertions in debug builds.
    • Fixed core compiler not recognizing several declarative properties, causing missing errors
      when declarative types are used inside non-declarative functions, especially in combination
      with declarative structs defined in the ::df module (bsdf_components and alikes).
    • Fixed pre-calculated arrays not being properly stored in texture results (HLSL/GLSL).
    • Fixed NaNs being generated by sqrt(+inf) for the native backend.
    • Fixed crash when compiling functions with derivative arrays as parameters.
  • MDL SDK examples
    • Fixed memory leaks in MDL examples.
    • Fixed trace_shadow function executing a generated MDL function potentially requiring
      texture results without providing them.
