Announcing Jetson AGX Orin Industrial
We are pleased to announce the new Jetson AGX Orin Industrial module, which brings the next level of computing to harsh environments.
This new module extends the capabilities of the previous-generation NVIDIA Jetson AGX Xavier Industrial and the commercial Jetson AGX Orin modules, by bringing server-class performance to ruggedized systems.
The Jetson AGX Orin Industrial module delivers up to 248 TOPS of AI performance with power configurable between 15-75 W. It’s form-factor and pin-compatible with Jetson AGX Orin and gives you more than 8X the performance of Jetson AGX Xavier Industrial.
This compact system-on-module (SOM) supports multiple concurrent AI application pipelines with an NVIDIA Ampere architecture GPU, next-generation deep learning and vision accelerators, high-speed I/O, and fast memory bandwidth. It comes with an extended temperature range, operating lifetime, and shock and vibration specifications, as well as support for error correction code (ECC) memory.
For more information read the blog
The new Jetson AGX Orin Industrial module will be available in July. Reach out to a distributor in your region to place an order now.
