another newbe question
what is the syntax for the MAKE command using PGVFortran in Windows XP on a 64 bit machine.
I went to a dos windows and type MAKE and I got the following error message:
‘make’ is not recognized as an internal or external command,
operable program or batch file
got same for “makefile”
Please advice
Tuli
Hi Tuli,
Do you have PGI Workstation installed? You will need one of those PGI Workstation packages install. It is separate from PVF package.
Hongyon
