Is there a deepstream example that takes multiple rtsp streams and infers them by combining them into one using NvBufferComposite?
Thank you.
Thank you.
In DeepStream SDK, we use nvmultistreamtiler to composite the frames into single video frame. You can modify config file by referring to document. Please check suggestion in
Deepstream application using NvBufferComposite
