I was Trying to find a way to get RIVA ASR working with AWS for transcription. The challenge I am currently facing is how to get real-time transcription working. I always get issue on either using gRPC or transforming the data.
I would like to know if anyone found an optimal way to do real-time transcription in AWS?
Below there is some thoughts:
AWS Kineses Video Data Stream → (some data transformation) → Riva ASR (AWS Batch EKS)
- If I use Firehose + Lambda it becomes slow and batch processing.
- If I create a new Batch EKS just for the data transformation it adds complexity among other challenges.
I might Edit the post as I go exploring and discovering new solutions.
Hi @Pappachuck_renan
Thanks for your interest in Riva
I will check regarding your request with the team and get back
I have some inputs from the team
Please follow the steps from How to Deploy Riva at Scale on AWS with EKS — NVIDIA Riva for deploying Riva API on AWS
Questions from the team
- For EKS Cluster setting, have you looked into managedNodeGroups configs?
- Can you share what the setting you are using for Firehose and Lamda ?
- Can you give specific details on errors which you get with AWS during transciption ?
Please provide the above details, will get back to the internal team and provide updates
Your example they used a Ingress through traefik and I assume they do transform the data on the cluster itself.
I have seen examples on TensorRT.
I was mostly curious about alternatives to what u present.
Ingress through a edge router is far from optimal.
So far I am just playing with ideas. I thought I could use Kinesis so I can have a more robust integration. Firehose is used for some ELT pipelines, pretty popular. lambda would just convert the encoding and send the job request.
I did not set anything yet. It doesnt feel right yet. I need to read more and see what can be done.
The ASR I cant get it working at all outside NeMo. I am following other post for that.
