Can anyone help me please.
Hello @pragyan52yadav
If you have preinstalled Windows or Ubuntu image flashed USB, there is a detailed guide for you:
also
Hope it works
Can I use it for Linux Mint too? Its Ubuntu based only.
Also what about the no gpu hardware issue?
Yes, it should work
Alternatively, you can try it with these commands (from Install Nvidia Drivers on Linux Mint [Beginner's Guide]):
$ ubuntu-drivers devices
$ sudo ubuntu-drivers autoinstall
You need to install a kernel 5.10+ and amd firmware files to get support for the ryzen 5xxx gpu, otherwise the nvidia gpu won’t work either:
You will need 4 packages
linux-headers-XX
linux-headers-XX-generic
linux-image-unsigned-XX-generic
linux-modules-XX-generic
from Index of /~kernel-ppa/mainline/v5.11.14
and copy all files green_sardine* from https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/amdgpu to /lib/firmware
Then add the graphics drivers ppa and install the nvidia driver using Software&Updates application.
I just installed Pop OS Nvidia version. Do I still need to do this?
Can you please elaborate the steps?
From what I understood, I need to put those 4 files and all files from amdgpu link to /lib/firmware and then add graphics drivers ppa and install nvidia driver
so how to add graphics driver ppa? and by install nvidia driver you mean install 460 one that I see in Pop OS update manager?
also how to download files from amdgpu link and what’s green_sardine*
please reply fast, I am currently on the pop os only so if its need to be done then before restarting I will do that. if its important than i will do it before restarting because it might go to black screen again if issue not fixed properly
The 4 kernel files have to be downloaded and installed (double-click or open with package-manager on download)
The firmware files for amd gpu ‘Cezanne’ are called green_sardine, ask amd why.
To download, click on the ‘plain’ link next to them on the right side.
See ‘adding this ppa to your system’ on
https://launchpad.net/~graphics-drivers/+archive/ubuntu/ppa
I just checked that OpenSuse Tumbleweed supports kernel 5.11 so I will be using that. Now from what I understand I can not add ppa to system this then. so how to that in opensuse?
